20 Most Recent Moen 24 In. Towel Bar... Questions & Answers
There is no screw here.
Insert a small flat screwdriver -- small enough to fit fully in the hole -- and pivit it up, so that the tip presses toward the wall. This should easily release the locking tab.
Moen 24 In.... | Answered on Apr 04, 2019
Hi. Are the brackets (mounting posts) the correct distance apart? For a 24" rail, they should be 26.22" apart (outside to outside). If they are not then they probably need to be moved so that they are.
If they are correctly spaced, are the "notches" in the mounting posts facing downwards? If not, make this so.
If the notches are facing downwards, are the screws tight enough? If, not, tighten screws.
Hope this helps. Regards, Myles
Moen 24 In.... | Answered on Nov 15, 2015
on both ends look underneath and there is a tiny hole with an Allen/hex head insert u turn counterclockwise wise and loosen srew until you can tilt end upwards towards the wall, reverse to install
Moen 24 In.... | Answered on Aug 14, 2014
Do the tips come off? Is it possible that the bar slides through the brackets? Most high end hardware has very small Allen screws to mount it. If not, go to Moen website for instructions or a phone number
Moen 24 In.... | Answered on Oct 04, 2013
Go back to the store where you bought it and tell them you didn't get the screws you needed. Or call the company and see if they will send them to you.
Moen 24 In.... | Answered on Jan 02, 2013
Newer towel bars don't have set screws... Solution-slide off! There is an opening in the bottom of the bracket. Slide your flat head screw driver inside the opening and place pressure on the bottom. Make sure you place enough pressure to allow the holder to slide off.. Now pull on the holder and it will snap off...
Moen 24 In.... | Answered on Sep 07, 2012
I think you grab hold of the rosette closest to the wall and spin it off, it should expose the set screw. If that isn't it, one of those things will turn. Try a few different spots. hope this helps.
Moen 24 In.... | Answered on Jan 07, 2012
for most towel bar and bath accessories there is a very small screw or allan bolt, located on the underside of the post, which holds the post to the mounting hardware and you can simply unscrew it to remove the post and then remove the hardware w/a screwdriver (usually phillips) saying that...i just looked up the installation instructions for moen towel bars and it says very specifically that the posts snap or click into place on the mounting hardware...it also refers to a square hole located on the underside of the post. perhaps we are meant to put a small flat head screw driver in there to release the "clip" and post. here are the installation instructions: http://www.faucetdirect.com/mediabase/specifications/yb2218_5624sp.pdf
hope this helps:)
Moen 24 In.... | Answered on Oct 13, 2011
Towel bars usually have a base that attaches to the wall with a screw. To expose the screw, you must loosen and or remove a small screw on the underside of the mounts. Once the screw is exposed just tighten it.
Moen 24 In.... | Answered on Sep 23, 2011
The base is probably connected to wall with toggle bolts, thus meaning , as you try to unscrew the bolts that keep spinning, pull on the bracket away from wall as you unscrew the bolts and it will come off.
Moen 24 In.... | Answered on Aug 31, 2011
Moen 24 In. Towel Bar... Logo
Popular Tags
41 questions posted
Top Moen Home Experts
Mike
john h
Bruce Robin
Are you a Moen Home Expert? Answer questions, earn points and help others
View Most Popular
Moen Home
  • Moen Home
Most Popular Question
remove towel bars hooks from wall no
  • Home
