Question about Moen Posi-Temp Single HandleTub And Shower Faucet
I have a moen 96909 cartridge removed and try to put the new one that i brought at Lowes, but the model is 1222. Are they compatible? i want to know before i put it in
Posted by japandycandy on
  • Anonymous Aug 15, 2016
    I spoke to Moen customer Service today. The 96909 is not the cartridge part number, it's the mold number for the plastic sleeve that's part of that assembly. Odd. If you have shower dial that rotates to turn the water on and off (doesn't pull out), they indicate 1222 is the replacement.
froizz taggz
    New Friend:
Absolutely
Posted on Apr 21, 2018
Anonymous
    New Friend:
  • 54 Answers
Your best bet,is to check with moen hand book or go online ,I don't usually get good answers from chain stores
Posted on Apr 13, 2010
Looking for a 96909 single lever moen faucet cartridge mine drips
You can purchase from Moen directly
here is the link to the replacement parts for you :)
http://www.moen.ca/replacement-parts
Nov 09, 2016 | Moen Plumbing
Remove stem of moen shower cartridge,
Moen makes a stem removal tool that angages the 2 ears on the outer portion of the stem. You can order from Moen:
http://www.moen.com/moen/cartridge-removal-tool-for-1200-or-1225-or-1222-cartridges/_/R-COMMERCIAL%3A104421
Or your local home center or hardware store should have one in stock if they carry Moen parts.
Jan 08, 2012 | Moen Plumbing
I have a moen single handle tub and shower faucet took out the clip and pulled but the stem will not come out what esle is holding it
You need to purchase a replacement cartridge before trying to remove a defective Moen cartridge. Always buy genuine Moen. If your valve turns on and off with a pull/push action you need part number 1225B, otherwise you need part number 1222. The 1200 cartridge will work in lieu of the 1225B but is more expensive and no longer used in Moen valves. There is a tool that comes with these cartridges which looks a bit like a white plastic cap.with notches on one end and a square head on the other.
Once the clip has been removed the only thing keeping the cartridge in the vslve is old sticky lubricant. Place the tool over the cartridge end and rotate as necessary until the notches are fully engaged and it no longer rotates. Using pliers or a wrench over the squared end, twist the tool back and forth several times. Remove the tool, and using pliers, pull the old cartridge out. Put the tool on the replacement part and insert it back into the valve. Lightly tap on the squared end to make sure the new part is completely seated, then use the squared end again to turn the cartridge as necessary to align for the clip to be reinstalled.
Nov 06, 2010 | Moen & One Handle Tub & Shower Faucet
Is the moen 96909 shower cartridge still available or is there a replacement part #
yes go to moen .com an enter part number there will info on how to order parts and schematics on line
Sep 19, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Moen faucet in bathtub that whistles and a very high pitch whine when shower is engaged recently purchased house and don't know model # how can I locate a relacement part
your cartridge's rubber's may be fluttering in water stream. causing the noise. had similar problem,and a new cart' solved problem.either #1222 or 1225 is possible # for new cart,' remove and take with you to hard ware store, or the home depot/lowe's
Jan 13, 2010 | Moen & One Handle Tub & Shower Faucet
New MOEN 1222 cartridge leaks
remove it and carefully inspect it, you might have scuff'd up the rubber's on the cartridge when you inserted new one.clean out,look in hous'ing for any foriegn mat.etc .you may need another new cart.
Nov 19, 2009 | Moen & Replacement Cartridge
Moen Posi-Temp Single HandleTub And Shower Faucet  Logo
10,180 people viewed this question
Top Moen Home Experts
Mike
john h
Bruce Robin
Are you a Moen Home Expert? Answer questions, earn points and help others
