The part number for a board I believe is compatible with my TV is B44-00808A but I have not been able to confirm its compatibility with the HD02 version, I have only seen HD01 listed.
SOURCE: One For All 6 URC-7562 702930
Unless you haven't tried the suggested 000-??? for a Samsung tv then you're out of luck. Remote codes are supplied by the manufacture to go with units. If the codes they give don't work, then there are none.
SOURCE: Samsung LN-S4051d power supply board
The replacement of the power supply is quite easy. You will have to remove the base if applicable and the back cover, once you remove it; you should see the power supply.
Click here to see how the power supply looks like and availability or Click here to find a cheaper one.
I can also repair your power supply. If you need further assistance you can write to [email protected]
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
SOURCE: compatible part needed for 4407-BESK4H
This is AO4407. You can replace it by any 30V P-Channel MOSFET, for example FDS4435 or other.
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
