You can get a replacement like this that fit any tv. uses the wall bracket holes on the tv, replacement tv stands can cost a lot. this is the cheaper option and they look better and more stable. https://www.ebay.co.uk/i/222345567503?chn=ps&adgroupid=52137191441&rlsatarget=pla-380309527891&abcId=1129946&adtype=pla&merchantid=113584017&poi=&googleloc=9046240&device=c&campaignid=974961043&crdt=0
SOURCE: aprilaire 550 humidifier
You can call 1-800-955-7075 give them the make and model #.The part # should be 4217,10x113/8 frame for $14.56 plus shipping
SOURCE: Touch focus error will not correct
If the touch focus isnt working and the picture has a 3D look you will need to change the conversion ICs. This is a straight forward repair just unsolder the old and solder in the new. You will need to replace both. They are located on a large aluminum heatsink and they will have STK numbers stamped on them they are quite large easy to find. The numbers will be something like STK392-110 or simallar. Let me know if you need anymore info.
SOURCE: Base Detachment
If you lay the TV down on something soft but firm (towel on the floor or counter) put the screen face down on the back you should see 4 screw holes with the an (S) next to them. They are located at the center near the bottom. If you remove these screws the stand should then slide out of the bottom of the TV. Good Luck
SOURCE: little tikes log cabin wall and door cracked in move
If the wall holding water is your concern, drill a large hole in the bottom of the wall where it meets the ground . Then, water will not collect in there.
If you are concerned with pinching little fingers then use a small amount of silicone caulk on the cracked areas and let it dry in the sun for about 12 -24 hours.
Let me know if you need anything else!
SOURCE: how do I set the ge timer model #15119. husband
I tried to pull the whole dial and doing that I discovered that the border of the dial is composed by pins that you can pull it up each independently, with your nail or with any pointing device. The rest is easy: get sure the switch is set at "timer on", turn the dial to the current time using the black triangle mark and pull the pin up in the time you want your device to disconnect.
