Water Heaters Logo
A
Anonymous Posted on Jan 24, 2018
Why my tankless water heater does not stay hot? The water temperature is inconsistent. It is cold and hot.
80stech
Level 2:
  • Expert 120 Answers
  • Posted on Feb 14, 2018
80stech
Expert
Level 2:
Answers
120
Questions
0
Helped
41876
Points
238
That is a drawback with tankless heaters, some worse than others and there might be something wrong if it was more consistant before but they are never perfect.
5 Related Answers
Anonymous
  • 716 Answers
  • Posted on Jan 16, 2009
SOURCE: No water flow from hot water tap with a rinnai tankless water hea
Its A Possibility The Left Over Water In The Hot Is Frozen. If Your Line Is Exposed Outside Somewhere It Can Easily Freeze Up. Turn On The Hot Water Everywhere In The House And If Accessible Check The Lines To See Where The Warmth Ends. You Can Leave One Off Over Night In Hopes That It Will Eventually Defrost.
Anonymous
  • Posted on Jan 17, 2009
SOURCE: Tankless Water Heater - Frozen???
I had them same problem with my AquaStar 125 back in 2005......it hasn't been that could around here since then until last night and it froze up again. The problem is the negative draft. This can be solved with the Power Vent Module and the AQ1 flapper....at least with the 125. It prevents the back drafts.
Anonymous
  • 152 Answers
  • Posted on Mar 25, 2009
SOURCE: No hot water
The code # 11 is a code that warns of "no ignition" and the causes of this error code are too many to list. I would suggest that a qualified tech. perform a diagnostic test and repair.
This is not a task for the "do it yourselfer"
Anonymous
  • 332 Answers
  • Posted on May 29, 2009
SOURCE: Paloma PTG 74PVN Tankless Water Heater
did you check the filters on the the water valves, i am not exactly sure about your codes that are shoeing but if you could read it and post them, i know on some of the units 76 means there is low water pressure and the filters are behind 2 caps one on each side above the shut off valve take off the caps and remove the screens, clean them and replace them ,, make sure you turn off the water on both side first or you will get wet
Anonymous
  • 248 Answers
  • Posted on Oct 31, 2009
SOURCE: rheem tankless water heater error code C4 13??
check diaphrapm valve or micro/switch best of luck
Error c4-15 what does that mean
Before calling service technician, copy following link for troubleshoot resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
C4 can range from failed PC Board to lime build-up inside heat exchanger
Error 15 is 'heat exchanger is too hot', clogged heat exchanger, restriction in cold water inlet, temperature set point too high.
If you recently changed temperature setting, then that might be cause.
Tankless require monthy-to-yearly maintenance to avoid common error codes.
Delime tankless and clean water filter, keep temperature low.
Never install tankless water heater is best way to avoid complications of expensive water heater that is maintenance heavy, hard to diagnose, expensive to fix, etc.
Never expose tankless to more than 11 grains hard water.
http://waterheatertimer.org/pdf/Rheem-CondensingTankless-maintenance-2012.pdf
http://waterheatertimer.org/pdf/Rheem-De-lime-tankless.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Rheem rte13 standby (green) light not on
You might have crossover problem caused by bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
The green standby light should come on when 240Volt power is applied. Page 6 manual.
Both red lights should come on when tankless is activated. Page 6 manual
RTE 13 requires 60 amp breaker and 6 gauge wire
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
http://waterheatertimer.org/pdf/Rheem-TanklessElectricUC_AP15447.pdf
Factory temperature setting is usually default 120 degrees.
Adjust temps page 11 manual
Thermostat calibration is always approximate.
120 degrees is not hot enough to burn the skin.
Exceptionally cold incoming water temperature can cause tankless not to heat enough hot water: install tempering tank to preheat water to room temperature.
Tankless cannot be exposed to more than 11 grains hardness in water. Delime tankless yearly, clean water filter monthly, do not install low-flow restrictions or conserve water since the flow rate must remain high for tankless to activate.
Rheem does not post service manuals for their tankless water heaters.
Call Rheem 800 432-8373
Why won't the hot water stay on when the cold water is turned on?
More information is needed.
Water heater type and model is not know. Add a comment with more information.
If you have tankless water heater, the temperature could be set too high.
Other causes can include dirty combustion parts, water filter needs cleaning, heat exchanger needs to be de-limed, loose wiring, bad pressure sensor, bad PC board etc.
Instruction manual says to have professional service once per year.
Resources:
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Other cause can be crossover.
Our rheem pronto tankless rutg-74xp red light will come home indicating hot water and stay on about 2 minutes and then turns off we have turned off and back on and let water run for 5 minutes and will come...
Before calling service technician, open following link for Rheem troubleshooting resources.
List of causes MIGHT include one of following:
Bad household circuit breaker that powers electronics, or loose wire inside outlet where tankless plugs in.
Tankless fuses and control board.
Water flow rate too low. Minimum .8 gallon required (depending on model)
Tankless inlet filter clogged.
Household aerators clogged at faucets.
Crossover at single-handled faucet
If installed, there can be crossover at mixing valve.
Faulty household check valve, including check valve on re-circulation system if that system is installed.
Restriction in household water line, such as clog at elbow.
Unequal pressure in household hot and cold lines, caused by restriction in hot line. When single-handled faucet turns on, the cold water pressure is higher so hot does not flow and tankless will not turn on.
Loose wire connection inside tankless.
Unit temperature set too high.
Unit temperature set too low.
Water temperature is very hot coming out of tap, so more cold is added, but that reduces amount of hot water flow, so tankless turns off because flow rate is too low.
On some tankless, if water is preheated by solar or other indirect source, the burner will not activate.
High mineral content in water > delime tankless yearly
Misaligned temperature sensor
Low gas pressure. Wrong type of gas. Undersized gas line.
Too many faucets on at same time.
Faulty tankless water valve. Water valve stuck.
Fluctuating household water pressure, for example MUD and PUD district water pressure problems or water well pressure.
Faulty household pressure reducing/regulating valve if installed.
Faulty household pressure tank, if installed -or- pressure tank needs to be installed.
Hot water tank does not work when shower is on, it does however work when the faucet in bathroom is on. It quit working in the shower about a month ago.
  1. COLD MIX, HEATER DEACTIVATES
    If inlet water temperature is over 70°F due to geographic location, water maybe very hot out of the tap. This requires a lot of cold water to be added with it in order to attain a useable hot water temperature. The addition of too much cold water will overpower hot water demand from the tankless water heater. This slows the flow within the tankless water heater, decreasing it below activation point, which shuts off the heater. The end result is nothing but cold water coming out of the outlet. See: TWH E2-04 Overcoming fluctuating temperatures [PDF].
  2. FLUCTUATING WATER PRESSURE
    If the water pressure in the home is erratic and the water flow is not consistent while a tap is opened, then the temperature of hot water will fluctuate. The minimum water pressure for the home should be 30psi or greater. For people on well systems the minimum pressure range is 30-50psi. The use of a pressure reducing/regulating valve is an effective way to maintain constant water pressure to the water heater. Watts brand 25AUB- ¾" or N35B-¾" pressure reducing/regulating valves or equivalent is suggested.
  3. CHANGING FLOW RATE
    Major changes in flow rate can adversely affect the output water temperature of the heater. Increases from one major fixture running to multiple fixtures running at one time can cause the temperature to fluctuate. Stay within the heater's specifications. See: TWH E2-03 Outlet temperature vs. flow rate [PDF].
From the Bosch website.
Good Luck,
Gary
Bosch tankless hot water heater: Confort TOO HOT!!!
Look for a water temp control on unit. Otherwise a lower temp can be attained by having a higher water flow to minimize temperature buildup in heating coil.
1helpful
Heats up the rapidly decreases within in minutes.
Problem new or old? How long you have unit? Sounds like not enough flow to keep burner on. Tankless need at least .6 gpm to keep hot water flowing or else the burner fires then shuts fires then shuts and you get a sandwich effect...hot cold hot cold. If you have new diverter valve in shower -vs- old two handle type try turning hot water ALL the way ON and see if hot stays hot. If it does stay hot then slowly adjust to cool and see if you maintain a good MIX for proper temp. If it goes cold again try this......LOWER control pad setting to a comfortable 105 degrees (ladies) 100 degrees(men) and turn shower valve all the way to HOT. See if your temp remains consistant now and if it does then problem solved. Tankless mindset...set temp on control pad and stop trying to MIX at shower valve. Thats how these things work. Thats why I install a control pad in each bath and one in the kitchen for adjusting ash temp during dishwasher on time. ditto for wash machine. You should never need to turn on cold water if your unit is set to proper temp at controller. Hope this helps
2answers
Exterior mounted Rinnai tankless water heater not
check to see if you have a blocked line on the hot water side
2answers
Water will not stay hot
The cold main water pressure is too low to maintain a constant flow. Make sure you have no other appliences on, or your not comprimised by the lowering of pressure
3helpful
Fluctuating temperatures
Sounds like there is not enough flow in order to keep the burner in the heater firing continuously
Top Water Heaters Experts
vince
Steve Sweetleaf
Steve Sweetleaf
Are you a Water Heater Expert? Answer questions, earn points and help others
