Question about Water Water Heaters
Water heater blinks 7 times. I don't get any hot water. Model # is MITW4056FBN
Posted by Darla Davis on
Dave Glabb
    Master:
  • 257 Answers
Hope this helps..I have also attached a link that may be useful.
No Hot Water
REASON REMEDY No power Check fuses or circuit breaker, replace or reset. Check with utility if necessary Wrong wiring connections at heater terminal Correct according to manufacturer's instructions Leaks around heating elements (1) Tighten element (2) If necessary, clean and replace with new gasket Loose wiring connection Locate loose connections. Clean carefully (remove all oxidation). Reconnect properly Lightning Inspect: (1) fuse (or circuit breaker). (2) Heater elements, and (3) thermostat, replace if necessary, see "grounding instructions" below High voltage Check utility for correction Short Locate short circuit and correct Wrong piping connections Reconnect pipes to proper fittings according to manufacturer's instructions Undersize service wiring Check with utility co. or electrician Improper calibration Replace thermostat Faulty thermostat Replace Faulty thermal cutout Replace Open thermal cutout Reset Top heating element burned out Replace
http://www.bradfordwhite.com/sites/default/files/product_literature/48494-A.pdf
Posted on Jan 13, 2018
5 Related Answers
Anonymous
  • 21 Answers
SOURCE: Whirlpool energy smart water heater
Two flashes means that the high limit temperature has been reached. Once this happens, the temperature control system will shut off. Make sure that all element access doors are in place. Push the "Push to Reset" button to restart the temperature control system. The water heater will self test for ten minutes before it will start to heat. If you get the 2 flashes again then you may need to replace one or both elements. Each element should measure 5-25 ohms.
The "thermostat" is the knob marked "Temperature Control". Make sure that the operating mode is set to 1,2 or 3.
Posted on Jan 13, 2009
Anonymous
  • 152 Answers
SOURCE: No hot water
The code # 11 is a code that warns of "no ignition" and the causes of this error code are too many to list. I would suggest that a qualified tech. perform a diagnostic test and repair.
This is not a task for the "do it yourselfer"
Posted on Mar 25, 2009
Donni Steen
  • 687 Answers
SOURCE: insinkerator hot water heater takes a long time to dispense water
It may have mineral deposit buildup on the inside. You will need to consult your maintenance manual to see how to flush the unit and clear it of deposits. You can also contact Insinkerator for the information as well. You can use vinegar to clean it just like you would a coffee pot. Take the inlet supply off and using a funnel pour the vinegar in and turn the unit on.
Posted on Apr 03, 2009
Anonymous
SOURCE: Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
Posted on May 12, 2009
Anonymous
SOURCE: how to correct error code C-7 on my RTG-74PVN Rheem Pronto
I had the same problem and called the manufacturer. The error code C-8 was followed by the number 76. They told me to disconnect the thermostat/digital display from the main unit. This was fairly simple to do by removing the front panel. The unit works steady now without shutting down after a few minutes. The help desk told me that the main circuit board needs to be replaced for the unit to work with the display and that they would mail me one asap. At least we have hot water again.
Oakville, Ontario
Posted on May 24, 2009
No hot water , no heater
No Hot Water - Electric Water Heater Troubleshooting
www.whirlpoolwaterheaters.com/owner-center/.../no-hot-water/
Whirlpool's video explaining potential reasons your water heater is not working ... Troubleshooting and Repair · No Hot Water (Video) · Replacing a Heating ...
Electric Water Heater Repair and Troubleshooting ' Whirlpool
www.whirlpoolwaterheaters.com/owner.../troubleshooting-repair/
Troubleshooting and Repair of a Standard Electric Water Heater. No Hot Water ... Not getting power is a common reason new water heaters don't work.
Troubleshooting Electric Water Heaters in MINUTES ~ Step ...
? 7:01
https://www.youtube.com/watch?v=SlyStHM9Nr0
Oct 4, 2013 - Uploaded by electronicsNmore
My tenant has a electric 30 gallon water tank. cimarron by Reheem. model ... So if u notice your water is overly hot and then notice no hot water ...
Dec 26, 2015 | Water Water Heaters
Whirlpool/Honeywell hot water heater light flashes 5 then 7 times and won't light. Burner is clean and all contacts are good. Out of warranted.
Copy following link to troubleshoot by type of gas control valve, including directions for cleaning air intake screen, and or replacing gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://www.thetankatwaterheaterrescue.com/forums/forum3/
7 flashes: Gas control valve might be bad.
4 flashes: FV overheat, clean air intake.
Soot indicates clogged air intake slowed combustion venting possibly causing overheating and lockout. Clean air intake screen located on bottom of unit.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 17, 2013 | Water Heaters
Should the red lights be flashing or be on steady
A solid light is what you actually want.
If you have a blinking light, the unit is unable to keep up with the flow of water.
Slowly turn on the hot water for your bathtub until the light starts to blink to find your limit. in other words your tankless heater is too small for your needs.
The 24 model is more for houses with showers or slower flow.
The 36 or higher model has 3 sets of heaters to be used with a bath, higher flow.
Jan 20, 2013 | Stiebel Eltron TEMPRA 24 Tankless Water...
7-25-11. Purchased Reliance 909 model 950 GKRT 200 natural gas hot water heater. 7-31-11, installed said hot water heater according to instructions and code, filled with cold water and checked for gas and...
The problem requires looking at manual and service handbook, except handbook doesn't show most recent water heater.
My first check point would be gas supply, and then vent draft, and then air supply.
Take off front cover and try lighting again to make sure air supply is not problem.
Review lighting instructions.
If there is no gas, and gas is turned ON, then gas control valve is suspect.
On-line manual for Reliance 909 gas
http://www.reliancewaterheaters.com/lit/om/manuals/186486-002.pdf
Reliance 2006 service handbook:
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
Other resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
Jul 31, 2011 | Reliance Natural Gas Water Heater Control
No hot water and low pressure
Your manual will tell you what that code means and what repair must be made.
Apr 04, 2009 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
Blinking red light,
It seams alot of people have this same problem All must get ahold of manufacturer and report this it must be there pump's thank you for useing fixya
Jan 14, 2009 | Noritz 6.3 Gallon Residential Tankless...
Water Heaters Logo
3,645 people viewed this question
Top Water Heaters Experts
Don Walper
Level 1 Expert
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Water Heater Expert? Answer questions, earn points and help others
