SOURCE: Beeping F11 error on Frigidaire
Hi im an appliance tech and i had the same problem its not the EOC other words control board its actually the speed bake swith its stuck in the on position that why you get a stock keypad error code either f1 or f11 replace that switch or disconnect it and im positive that this will solve it .
SOURCE: F11 code on my kenmore range. The repair says the
No. Other than order the part from Sears.com and install it yourself.
Thank you for your inquiry, Katherine!
Based off the information you have provided your Frigidaire range is displaying an error code of "F11". An "F11" error code stands for a shorted keypad I would recommend performing a reset on your range. You can do that by flipping off the household circuit breaker for at least ten minutes. If that does not correct your issue it could be a possible problem with your EOC (Electronic Oven Control) or wiring harness. Hopefully this information is helpful for you. -Matt
I appreciate your inquiry, friend!
I see that you are having a difficult time with your Frigidaire range displaying an "F11" error code. That error code stands for a shorted keypad and I would recommend performing a reset on your range. You can do that by flipping the household circuit breaker off for roughly ten minutes. If you restore power and continue to receive an "F11" code you may need to replace the EOC (Electronic Control Panel) this is not a simple DIY job. I would recommend contacting a professional technician for proper disassembly and repairs to be completed. I hope this is helpful information. -Matt
1. (F11, 12 & 13)
Disconnect power, wait 30 seconds and reapply power.
2. (F11, 12 & 13) If
fault returns upon power-up, replace EOC.
EOC = Electric Oven Controller
