20 Most Recent Frigidaire HD4130 / HD4130W / HD4130Q Kitchen Hood Questions & Answers
hello. go to searspartsdirect.com
enter your model number
click on model
you will get a schematic showing the parts, and you can order the proper filter there too or at least get the correct part number for your model. joe
Frigidaire... | Answered on Apr 15, 2011
Sounds like a problem in the oven control board, something not easy to test. That said, I don't find your model number. It would have been helpful to know the error code, something you didn't supply. You might repost a query with the error code and the model number.
Sometimes a reset can be achieved by simply shutting off a circuit breaker and then closing it again. Or, the bottom panel of an oven might slide out give you access to a plug if the oven is not hardwired to your living quarters. But if the stove comes back to life sporting the same error message, I suspect you are destined to access a repairman or a new stove. Still, you might get some information below. Sorry, without the model number and error code, there is not much more I can determine about this.
If your stove is under warranty, the following may be of assistance.
https://www.repairclinic.com/RepairHelp/Range-Stove-Oven-Repair/13-2--/Frigidaire-Range-Stove-Oven-Troubleshooting
Frigidaire... | Answered on Apr 02, 2020
Hi Junior-
I found this youtube video on resetting f10 code on a gas stove.
https://www.youtube.com/watch?v=z6tcnpDKDns
Hope this helps.
Frigidaire... | Answered on Nov 28, 2019
Due to the cost of parts on this range, I would call an engineer. $310 for the oven control board, $400 for the 2 elements.
The only thing I would suggest is checking the contacts at the back of the back panel. you must have checked the element contacts when you did the continuity test. I have seen contacts get hot and snap off.
https://www.partselect.ca/Models/LGEF3045KFK/Sections/Backguard/?ModelID=6747678&ModelNum=LGEF3045KFK&mfgModelNum=&ManufactureID=4&Selected=BA2790DC09E1C5239A8B7CD13A1069F3169E482E&Position=1&mfg=Frigidaire&Type=Washer&Mark=1
Frigidaire... | Answered on Aug 13, 2019
Dear IFE KIARA,
Warning: If you feel in any way uncomfortable/unsafe performing this test or making this repair, please contact a qualified appliance repair technician.
F13 error is related to the clock. this error can occur when the clock looses communication between the keypad or any of the sensor in the stove, including the heat probe. sometimes resetting the power will fix the problem.
Try disconnecting power to the stove completely and flip the corresponding breaker on and off at the breaker box.
Wait 30 seconds and then turn everything back on.
if the problem persist after power-up, according to Frigidaire suggested corrective action the electronic oven control,also called EOC has to be replaced. Here is a search link from Google for the part in question.
Best of Luck,
JP
https://www.google.com/search?source=hp&ei=fecFXYCMAsKr5wKBm6G4DQ&q=316418735&oq=&gs_l=psy-ab.1.0.35i39l10.0.0..5525...1.0..0.209.209.2-1......0......gws-wiz.....10.8VUU1xaL8qM
Frigidaire... | Answered on Jun 16, 2019
Hi im an appliance tech and i had the same problem its not the EOC other words control board its actually the speed bake swith its stuck in the on position that why you get a stock keypad error code either f1 or f11 replace that switch or disconnect it and im positive that this will solve it .
Frigidaire... | Answered on Jun 13, 2019
As copied from the manual.
Setting a silent control panel
When choosing a function, a beep will be heard each time a pad is pressed. If desired, the control can be programmed for silent operation. Press and hold (start/time) . After 7 seconds, the control will beep once. This will block the controls from sounding when a pad is pressed. To return the sound, press and hold (start/time) again for 7 seconds until the control beeps once
NOTE!
The OVEN indicator light on the electronic display will turn ON and OFF when using the Bake feature and during preheat. This is normal and indicates that the oven is cycling to maintain the selected baking temperature. When the preheat indicator light turns OFF, your oven is ready.
Frigidaire... | Answered on Jun 05, 2019
Yes, the microwaves will still be contained,however it needs to be replaced. super glue will work if the original parts are broken or lost
Frigidaire... | Answered on Apr 25, 2019
Frigidaire HD4130 / HD4130W / HD4130Q Kitchen Hood Logo
Popular Tags
1 questions posted
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Kitchen Ranges
Most Popular Question
trying buy replacement filter
  • Kitchen Ranges
