20 Most Recent
Frigidaire PLES399EC Electric Kitchen Range Questions & Answers
We are geting a F
Your F11 error code is displayed below. It would be best to have the unit serviced by a professional for this type of fix as if not performed properly, the fix could end up costing over $500.00.
F11 Shorted Keypad.
1. (F11, 12 & 13)
Disconnect power, wait 30 seconds and reapply power.
2. (F11, 12 & 13) If
fault returns upon power-up, replace EOC.
EOC = Electric Oven Controller
How do i attach the
If you are referring to how to attach the appliance power cord, the following link explains how:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Pay particular attention to how the Ground and Neutral wires are terminated on the 3 and 4 prong configurations. Depending on which type of power cord you have, there is a difference in how these wires are terminated.
If you have any questions, please post back and let me know. I hope this helps you.
Getting F13 err code when trying to bake or
Hi william_j522,
the F13 error is related to the clock. this error can occur when the clock looses communication between the keypad or any of the sensor in the stove, including the heat probe. sometimes resetting the power will fix the problem.
try disconnecting power to the stove completely and flip the corresponding breaker on and off on the breaker box.
wait 30 seconds and than turn everything back on.
if the problem returns after power-up, replace the clock.
Regards
R.K.
Broken cooktop
look just call frigidaire and tell them it just cracked it has a five year warranty the tech don't care he gets his cash his pay for fixing it not being a frigidaire police man just tell him it cracked you don't know why they have a five year warranty could have already been cracked when you got it and you didn't know now couldn't it
How do I turn the volume down or turn off the beep from my Frigidaire Gallery 5.0 cu. ft. Gas Range when the oven reaches its intended temperature?
As copied from the manual.
Setting a silent control panel
When choosing a function, a beep will be heard each time a pad is pressed. If desired, the control can be programmed for silent operation. Press and hold (start/time) . After 7 seconds, the control will beep once. This will block the controls from sounding when a pad is pressed. To return the sound, press and hold (start/time) again for 7 seconds until the control beeps once
NOTE!
The OVEN indicator light on the electronic display will turn ON and OFF when using the Bake feature and during preheat. This is normal and indicates that the oven is cycling to maintain the selected baking temperature. When the preheat indicator light turns OFF, your oven is ready.
Beeping F11 error on Frigidaire
Hi im an appliance tech and i had the same problem its not the EOC other words control board its actually the speed bake swith its stuck in the on position that why you get a stock keypad error code either f1 or f11 replace that switch or disconnect it and im positive that this will solve it .
How to I adjust the flame in a Frigidaire gas oven.
No orifice for the oven jet? All work on gas appliances needs to be done by a certified gas technician. Somewhere, normally just behind the knob, there is an adjusting screw (certainly for hobs). The flame must be high enough that it can't blow out. The standard test is the slam the oven door, with your kitchen windows closed and then again with them open. Help in the link, but also the pressure from the tank _at_ the range should be checked.
https://www.google.com/search?q=oven+flame+adjustment
