I have replaced both the condenser motor, and the fan, but nothing else.
SOURCE: High-pitched noise
Could you specify if noise is coming from : - The freezer - The outside back of the refrigerator - The bottom of the refrigerator
SOURCE: fridge is whistling
Mine was making a moaning, whistling noise coming from just above the ice maker. It happened when the fan speed changed. I learned on this site that the motherboard was probably defective.
Rather than go thru GE, we found a new one online for 66 bucks. I replaced it in about ten minutes and it's all fixed. Poor materials on the original, but this site was very helpful.
SOURCE: Whirlpool Gold Refrigerator Buzzing sound when motor is on
some thing could be toching the fan at the back of the fridge or freeze fan making noise
SOURCE: high pitch
The Hoover Fusion has design flaws in the motor, including a metal plate that is too thin to contain the forces acting on the motor, particularly the constant strong tension from the drive belt, and a plastic plate that is attached to the metal plate by two screws that gradually loosen over time. Assuming the filters and canister are clean, a high-pitched noise coming from the motor indicates it is about to fail as a result of these problems. You can replace the motor after it fails, but the problem will eventually occur again. For those very mechanically inclined, when the motor first starts making the high-pitched noise, you can dismantle it and tighten all screws.
We have summarised all possible problem for this case here to this link
http://www.fixya.com/support/r6008187-side_side_refrigerator_whistling_sound
