SOURCE: Norelco 3805 XL Battery Replacement
I was able to open mine with a 2.4mm slotted screwdriver from one of those mini-screwdriver sets you can get at the store for a couple of bucks. Be aware that the batteries are soldered to the circuit board in this particular razor.
SOURCE: How to replace batteries in Norelco 6826 XL
Amazon has a number of reviews that tell how to do this. See
http://www.amazon.com/Shaver-Battery-Norelco-models-others/product-reviews/B000FP63M4/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
SOURCE: Norelco shaver service centre in India
i am based at hyderabad india and wish to get my norelco shavers modelno4852XL and 7864 repaired is there any sevice centre in hyderabad andhrapradesh india
please email me on [email protected]
SOURCE: How do you change the batteries in the Norelco
Start by removing the two screws on the back and remove the back cover. You will then be able to see the batteries. They are soldered to the back side of the circuit board. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find batteries for model 5801XL at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
If you are not able to do this yourself, shaveroutlet.com can do it for you. See information link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
SOURCE: Norelco 5825XL Replacement Blades
HQ5 is not compatible with HQ55. I've checked the Service Manual and HQ5 is the correct part. It's got to do with the driving mechanism for the head.
