Lands Phones Logo
chan sooknanan Posted on Sep 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am dialing my niece in Trinidad but i am getting busy signals 2 days now
Tony Waldron
Level 3:
Master:
  • Master 201 Answers
  • Posted on Sep 21, 2017
Tony Waldron
Master
Level 3:
Master:
Answers
201
Questions
0
Helped
93414
Points
2580
Where are you dialing from/ what country are you in.
All countries have this sequence of numbers to call another country;
IDD COUNTRY CODE CITY CODE PHONE NUMBER Dialing Instructions
  1. Dial the International Direct Dialing (IDD) number. Countries have different numbers, or may have more than one IDD, depending on the carrier or type of service.
  2. Dial the Country Code. In some cases, the country code is shared among countries. For example, the United States, Canada, and much of the Caribbean and Guam use country code 1
  3. Dial the city/area code (if any) for the number you are dialing. Smaller countries may not use city codes or area codes, while larger countries have hundreds of them.
  4. Dial the phone number you are calling.
How To Dial Internationally
5 Related Answers
Anonymous
  • Posted on Oct 11, 2008
SOURCE: purchased 2 ge phones model
That sound is notification of voice mail. This phone does not disconnect incoming calls on answering machine extension so your phone is actually off the hook for hours without your knowledge.
Anonymous
  • Posted on Nov 04, 2008
SOURCE: fax machine error
I called Kodak support and had to upgrade firm software and reset all the settings to reflect whether I had an answering machine (yes) and call waiting (no). Also found it helpful sometimes to dial out using commas after the 1, to keep it from ringing busy.
Anonymous
  • 98 Answers
  • Posted on Nov 24, 2008
SOURCE: phone will not work. you
Try taking the cover off of your phone jack and reversing the two wires that are running to the actual jack that your phone line plugs into. There is very little voltage, so you have little worry of any kind of shock. Reversing these wires should fix your problem. Hope this proves to be of use. Have a great morning!
James
Anonymous
  • Posted on Jun 20, 2009
SOURCE: no dial tone/ others trying to call get busy signal
Turns out that it was a wiring issue and not the phine.
Anonymous
  • 580 Answers
  • Posted on Nov 01, 2012
SOURCE: after dialing 4 numbers the phone goes to a busy signal
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
I get busy signal when dialing from contact list in my Uniden Dect 6.0
New telephone company procedures in many areas now
require that all 10 digits be dialed even for local calls --
Area Code + Exchange + Number
Perhaps your Directory listings do not include the area code ?
Dial out always busy
View topic - Fast Busy Signal when Calling out - Ooma
www.ooma.com/forums/viewtopic.php?f=4&t=13773
May 15, 2012 - I'm out of town, but yesterday I tried calling a few numbers and alwaysgot the fast busy. Incoming calls were fine. I rebooted the telo and it still ... Can't Dial Out To Same Area Code
Feb 4, 2014
Can't dial out
Dec 3, 2011
Can't make calls, can't receive calls, but I have ...
Sep 13, 2011
cannot dial out and dial in
Nov 1, 2010
More results from www.ooma.com
Jan 26, 2016 • Cell Phones
4helpful
Panasonic KX-TCD220E - pulsating busy signal for a few seconds then dial tone
If that pulsating tone is anything like what I sometimes here on my phone, then it has nothing to do with your phone. It's your telephone company telling you that there's unheard voicemail on their system. You'll need to contact your telephone service provider for instructions on how to access their voicemail system.
I cant fax
Take your cell-phone, and dial the same number, to see if you get the same "busy" signal.
If the telephones in your business require you to "dial-9" to get an "outside" line, be sure that your FAX is also following that "dial-9" protocol, and also waiting 1 or 2 seconds after the "dial-9", in order to get the dial-tone from the "outside" line.
1helpful
Call receptionist and dont get busy signal
You need to dial two commands on the receptionist's phone. On the intercom dial 7311# for outside line call waiting signals and 7321# for inside calls. (0 cancels).
Carl
1helpful
Fax machine error
Purchased 2 ge phones model 29585 installed and ok for several days.now when picking up receiver to dial out we get a pulsating busy signal for a few seconds and then the dial tone and are able to dial,...
BUSY SIGNAL WHEN DIALING OUT ----ALL PHONE NUMBERS
busy signal can mean another phone on your line is till connected. remove each phone one by one till the line is open, this can be also a redial on a phone activating by itself, or if you have forward messaging activated it can do this as well if it stuck on.
Jan 30, 2018 • Cell Phones
52helpful
6answers
NEC Dterm 80
NEC Dterm 80 phone, 1 ext. is blinking and we can't get it to turn off. It shows a busy signal when you try to call it.
Help it is the owners phone!!!
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
