I tried rebooting it and Formatting ot and nothing seems to work....It displays the sansa and the computer connected but is stopped in mid movement......it's like a frozen computer screen.......what should i do to fix it so that it won't freeze and it will allow me to put music on?
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Please RATE my solution at the bottom.
I create my playlist in Windows Media Player then plug in my Sansa and it starts to synch then it freezes up. No songs make it to the player's memory. This happens every time.
i tryed i lot to switch off , but i cant , after a long time its ok, but now i cant open any folder, but i can listen to music
it will not let me put music on it
