j
james sagraves Posted on Sep 17, 2017
Hook up external amp for atmos on my marantz sr7010
Can veon 2.1 soundbars software be updated
I believe that Dolby Atmos would require a hardware change. Atmos has at least two extra channels. This would mean extra amps installed.
How do I hook up 2 preamps for the front right and left 1 for each channel on a Marantz SR6007? Can I even do it or am I just allowed 1 preamp for the fron right and left channel?
Hi Mark,
One can hook-up as many peamps as desired to the SR6007 either as sources or destinations. How to connect external preamps to the SR6007 depends on what you wish to achieve.
The SR6007 already has its own internal preamps.
You could, if you are not careful, burn the AVRs input circuitry by adding external preamps as "sources". Also, not much improvement in SQ could be gained by external preamps connected to the SR6007's preouts becuase any signals that come out of these have already been processed (or distorted?) by the SR6007s internal preamps.
How to hook a carver TFM 45 to a Marantz AV 8003 pre amp with Bose 901 speakers thank you very much
The output of the Marantz will go to the input of the Carver. The Bose EQ has to go into a Tape Monitor on the Marantz, or, you can connect the Marantz output to the Bose line in(not tape in). The line output of the Bose, to the Carver input.
Is there anything else I'm missing?
How to hook up a Marantz AV 8003 pre amp to a carver TFM 45 amplifier
Marantz preamp out, to Carver amp(or line in). Have you tried this and had problems?
How to hook up a Marantz AZ8003 pre amp to a carver TFM 35 a.m.
Please see my last few comments on the same issue. If you can't find it, please let me know. BTW, Marantz does not show the AZ8003 to be a valid model.
Can i hook up 4 8ohm speakers to my marantz 2252b
You can but you will have to put two speakers on the main L/R and two speakers on the remote L/R. DO NOT HOOK UP MORE THAN ONE SPEAKER TO A CHANNEL. Doing so can result in the amp running hot and damage will occur.
The second phone in our Wharfdale atmos twin phone set doent work
how can i check the trasmission oil on a 2005 pontiac sunfire
1helpful
2answers
No Audio when I play Blu-Ray discs with Dolby TrueHD
For dolby digital to work you have to have the optical or coax cable hooked up to the reciever ,The HDMI cable is for digital video and audio output but does not support dolby digital out the cable into your reciever , so just turn off the dolby digital on your reciever and you should hear the sound.
here is more info
Dolby TrueHD is an advanced lossless multi-channel audio codec developed by Dolby Laboratories which is intended primarily for high-definition home-entertainment equipment such as Blu-ray Disc. It is the successor to the AC-3 Dolby Digital surround sound codec which was used as the audio standard for DVD discs. In this application, Dolby TrueHD competes with DTS-HD Master Audio, another lossless codec from Digital Theater System.
Dolby TrueHD uses Meridian Lossless Packing (MLP) as its mathematical basis for compressing audio samples. MLP was used on the earlier DVD-Audio format, but details of TrueHD and DVD-Audio differ substantially. A Dolby TrueHD bitstream can carry up to 14 discrete sound channels. Sample depths up to 24 bits/sample and audio sample rates up to 192 kHz are supported. Like the more common legacy codec Dolby Digital, TrueHD bitstreams carry program metadata. Metadata is separate from the coding format and compressed audio samples, but stores relevant information about the audio waveform. For example, dialog normalization and Dynamic range compression are controlled by metadata embedded in the TrueHD bitstream.
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
xxxxxx xxx
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
