Can veon 2.1 soundbars software be updated
Can a 2.1veon soundbar get it's software updated to a Dolby Atmos
Posted by Stephen Leslie... on
My plustron fr270 cuts out after 5 seconds thanks,help required please.
Please try to update your soundbar by following the steps below:
  1. On the remote, press the SoundTouch button.
  2. Press and hold the Closed Captioning button until the Wi-Fi indicator, TV indicator, SoundTouch indicator and Bluetooth indicator on the soundbar blink white.
  3. The soundbar restarts when the update is complete.
    Note: The update may take between 8 and 30 minutes. Update time depends on wireless network activity and other wireless interference in the area.
If this does not help, try to factory reset your soundbar:
  1. On the remote control, press the SoundTouch button
  2. Press and hold the Teletext button (to the right of the CC button on the remote) for 10 seconds until the Wi-Fi, TV, SoundTouch and Bluetooth indicators blink white on the soundbar
    The soundbar restarts and the Wi-Fi indicator on the soundbar glows amber (setup mode) when the reset is complete
  3. Restore the soundbar's network and audio settings by launching the SoundTouch app on your smartphone or tablet, add the system to your network and run the ADAPTiQ audio calibration
Howdy. My name is Gary Taylor. I have a new, purchased from Samsung, HW-K950/ZA soundbar with Dolby Atmos. functioned perfectly for 1 hr then Arc dropped out. Any suggestions. Gary.
ARC is the audio return channel. Make sure the latest HMDI cable is being used. Check the cable at both ends. There is a start order to the setup and the television unit should be started first, then the sound bar. This includes the power sequence. Unplug the television AND the bar, plug in the Television and power it on, plug in the sound bar and turn it on..
I have a Sharp Aquos LC-60LE640X TV and I am trying to connect a Samsung HW-H751 Soundbar to it. I have hooked up the optical cable, adaptor and sub woofer, I have tested the Bluetooth function throug
If you are connecting the soundbar to your TV with the digital audio cable, make sure to select "D IN" using the source button on the soundbar. Bluetooth (BT) is a separate source from another device. (phone, etc.) The TV will need to be set to use the digital audio output and probably PCM format. (?) The subwoofer is preconfigured at the factory to mate up with your soundbar. (See below instructions - your soundbar includes the amplifier:)
Digital audio output setting:
After connecting an amplifier with digital audio input and
external speakers as shown, you should set an audio
output format compatible with the programme you are
watching or the device connected.
Go to "HOME" > "TV Menu" > "Setup" > "Option" >
"Terminal setting" > "Digital audio output" > select
"PCM" or "Bitstream".
NOTE
• When set to "Bitstream", Dolby Digital is output when the Dolby
Digital or Dolby Digital Plus audio formats are received. When
set to "PCM", PCM is output no matter what audio formats are
received.
• When set to "Bitstream", HE-AAC audio formats can be output
as Dolby Digital.
Does the Samsung UN50f6300af smart led tv support the Samsung Wireless audio soundbar HW-H450?
Because your TV is not Bluetooth-enabled and you are trying to connect it to a Bluetooth-enabled soundbar via Bluetooth. There are other ways to connect your TV to the soundbar:
1. analog AUDIO OUT (L/R) of your TV to the AUX IN on the soundbar (use a 3.5 mm.-to-RCA audio cable).
2. Optical OUT on your TV to Optical IN on the soundbar.
3. HDMI port to HDMI port (this may not work if your TV is not ARC compliant you have to try).
You get better sound quality with option 2.or 3. (if this one works for your TV)
Here is the link to download the soundbar's User Manual for help with the connections:
http://downloadcenter.samsung.com/content/UM/201411/20141114104022428/HW-H450-ZA-1114_Bookmark.pdf
Hi, I have a hwh450 soundbar, I cannot get any volume to TVs, the tv is telefuken
Here is a link to your product description. When you get to the web page, click on the "Manual" tab to read the user's manual to find out how you can connect your soundbar to your TV.
HW H450 Wireless Audio Soundbar Samsung Home Audio
2answers
My soundbar won't turn on. It was working fine and just stopped.
Same here ?? I repair computers from home and did basic troubleshooting to no avail
3helpful
2answers
Purchased LG HLB54S Blu-ray Soundbar - I would like Multiregion
Just got the software to unlock it. It you dont have please let me know your model so I can send you the file. Quite big though.
2answers
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Marvin
Marvin
