SOURCE: Washing machine not spinning
check for a capacitor on the motor if it has one, replace that to start with, that what it sounds like
SOURCE: SIEMENS WXLM112GB FRONT LOAD WASHING MACHINE
Perhaps the exit hose behind your machine is not at the correct height, about 3 feet from ground. Your pump pumps the waste over this height, into your standpipe or sink; check this out.
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
SOURCE: Washing Machine on the blink mainly due to no spin/drain cycle wo
check your drain filter, get a wet vac and vacuum the water out, then open the drain plug at bottom and try to vacuum the drain to clear out debris......then turn on and test washer if it fills and drains if it fills with water and doesn't drain then your drain pump is defective........get your model number and source for a pump motor.................................
if it doesn't fill with water then your water fill switch is defective...............source for parts..............
if this helps out anyone a feed back would be good..........
