SOURCE: My Polaroid TV model not listed, it's TLX-04240B
I got the 42" Polaroid HDTV from Walmart (on Black Friday) and was able to link it to my Tivo remote using the Mitsubishi setting and code 0001.
1. Tivo Central
2. Settings
3. Remote Control
4. Part 1 and then Part 3
I use it to Power On/Off and Volume control.
SOURCE: Need Universal Remote Code For Polaroid TTM-2420 TV
I recently found a remote that does work for this TV. Its a DirecTV model RC64. The codes listed in the book do not work. So you must do a channel search. It's not that far down the list so it doesn't take that much time. I hope this helped those concerned.
SOURCE: I cannot program my Directv RC 23 remote to operate my Polaroid t
Here is the list from Direct tv with your Polaroid TV Codes:
Polaroid
10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328, 11341
***Note: White remotes RC16, RC23, and RC24 may not be programmable to some later TV models
I hope this helps,
David
If my solution helped please rate accordingly
SOURCE: my remote control for my polaroid tv wont change channels.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
