From its manual, page 14. Dishwasher Does Not Drain
Properly
•If unit is hooked up to a food waste disposer, make
sure the disposer is empty.
•Check to see if the knockout plug has been removed
from inside the food waste disposer inlet.
•Check to see if drain hose is kinked.
•Make sure cycle is complete, not in a pause.
https://www.youtube.com/watch?v=diLwy0HZdd4
Above link is a Frigidaire Diagnostic link
Frigidaire Dishwasher Water not Draining Troubleshooting and Repair
Note some of the uTube videos beside these links. Some even cover pump replacement. Others offer generic advice. If the links above do no fix the problem, you at least have eliminated some potential causes and can go from there.
SOURCE: Frigidaire Dishwasher
A common problem with dishwashers is the non-draining machine. If you are having trouble, check to see if the drainpipe and sink trap are clogged. If you still have drainage problems after doing this, check your drain hose to make sure there are no kinks or bends. if the hose looks worn out you can replace the hose pretty inexpensivley. if your have thoughly checked from dishwasher to trap under the sink where your dishwasher should drain to and it seems clear you may have to call in the repair man.
SOURCE: water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
SOURCE: How to get to the drain line on my Frigidaire side
I will help you if you want. Just seems like sometimes I write to people that never respond or even come back to read the time I donate to help here.Most times not even a rate or thank you,. You will need to unplug your refrigerator and place the frozen contents in a safe cold area as you remove the rear panel of your freezer. The Defrost condensate drain is below the evaporator and behind the rear panel of your freezer. Click here and Scroll Down to=>
REPAIR OF LEAKING REFRIGERATORS then clickon photo and takes you to the authors. Watch this move=>
Rate Me or just say thanks,
If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
SOURCE: Frigidaire Gallery Series GLTF2940 front load
check the belt make sure it is still contected.
if that is good you may have a faulty door lock
SOURCE: I'm having a problem with my frigidaire front
If water remains in the drum the unit will not go into the final spin. There may be a couple of reasons which I have experienced resulting in your problem. If water remains in the tub the unit will not go into the high speed spin. 1.) A coin or other foreign object is blocking the drain hose. Check the drain hose for foreign objects impeding the exit of the water. Shake the hose and listen for coins or a small object this unit will pass items through the pump into the hose causing blockage. 2.) The Drain hose is not raised above the machine outlet to create a siphon effect. See your manual for proper hose positioning. The hose needs to have a loop in it to work correctly. 3.) The pump is a third possibility which you should hear the impeller spinning during the drain cycle. There is a coin catch after the diaphragm of the pump that looks like a rubber boot that should be inspected for objects if you remove the pump. The pump is about $60.00 and is accessible after removing the front panel under the door. It is easy access from the front and the hose clamps will be the most difficult problem. I have a ratcheting hose clamp tool designed for this type of clamp but channel lock pliers will work.
Hello Cicl, I appreciate your post!
If you have a water leak from under your Frigidaire washer it could be a possible problem with a faulty water hose, water inlet valve, or drain pump. Either one of those components could be causing a drain within your washer. Since it could be any one of these underlying issues I would suggest seeking assistance from a professional technician to get a proper diagnosis and repair. I hope this is helpful. -Matt
Hello friend, I appreciate your post!
I see you are asking about a Frigidaire washer leaking but your question is labeled under refrigerators. If your washer is leaking it could be a problem within your motor, water valve, drain pump, or seal inside your washer. If you are speaking about a refrigerator it could be an issue within your water valve, water filter, or an air leak causing condensation.
I would recommend having a professional come out to the home for a proper diagnose and repair. I hope this is helpful. -Matt
