SOURCE: installed majic jack, sound is distorted and jerky for me
we have same problem and cannot find solution??????????????
SOURCE: MAJIC JACK COMPUTER PHONE HANGING UP ON IT'S OWN
hi there, i have a magic jack and i'd like to use the voicemail the recorded voice is asking me for a mailbox assigned in my system, i'm usinf window vista and i dont know where to get a mailbox number please help!!!
SOURCE: im located on Guam USA, could a majic jack still
Hi well sorry but NO I do not think that it can.
SOURCE: MAJIC JACK PHONE WILL NOT RING
I believe that the redirect call service was activated and remain active ..or the phone is on silent mode and this cause it being redirected after a number of calls .(this is correct only if the mobile starts ringing after a few rings ...check it ..cause if it starts right the way it means it is redirected from start ..) ..To avoid all these I suggest to look in the setting menu of the phone ..and select to load default or factory setting s..This will make it loose the redirect settings ..or ...disconnect it ..and remove its batteries for a while ..and it eill also get to the factory settings ...remember this may need a reset for any settings it uses if it is an Ip p[hone and not a direct plug and play device ..
SOURCE: old majic jack want to start new program
If you have an old Magic Jack, my 4 unit are 6 years old the company just really wants you to upgrade to a newer product no need to. Try removing Magic Jack completely from your tablet, restart unit, make sure to clean out all junk on tablet from Magic Jack you could try a program that cleans your tablet for you, but unless you know what to remove don't get technical just a standard clean up of old files, this is usually under apps, Magic Jack, then there will be a clear cash button, clear data, and uninstall.
Restart unit then do a fresh install of Magic Jacks new app for your type of tablet from Googles sight or Magic Jacks make sure if you have a Mac to install the Mac App and if you have an android tablet you install the Android App. This has been working for me. With the old Magic Jack you will need to do a fresh install when you get errors and crashes. I do it 2 or 3 times a year. Good Luck!!
