Question about magicJack Two, 2 Magic Jack Plus Voip Phone With Or Without Computer In Box
I can call out on my Majic Jack Plus but cannot receive calls. The majic Jack is registered and set up on my modem.
Please advise. I have a majic jack plus set up at another address and it works fine.
Posted by William Divale on
C. David Graves
    Novelist:
  • 69 Answers
This could be failure of the power adapter module.
Is your Magicjack plugged into the wall power thru a power adapter? Try bypassing the power adapter and plugging the magicjack directly into a USB port on your computer. If the magicjack work correctly now, then you have a bad power adapter module.
I had a similar problem. My Magicjack was plugged into a wall socket. First the dial tone became inconsistent, then I could no longer receive calls, then it died completely.
I plugged the MJ into a USB socket on my computer, and it then worked normally.
If you have a failing power adatper, it will continue to deteriorate, and it will eventually fail completely. The blue power on the magicjack will not come on when it is plugged into the power adapter, but it will illuminate when plugged into the USB socket on the computer.
Note: the computer must be on to power the magicjack thru the USB port.
Magicjack is aware of the problem and offers a replacement power adapter module. To contact them, go to www.magicjack.com and go to "support". They will ship you a new power module for about $5.50. Some people have reported that the replacement modules from Magicjack are no better than the originals and have had repeat failures.
Consider getting a power module from another source. There are lots of AC to USB power converter modules available on Ebay for only a few dollars. Search Ebay for "magicjack power adapter".
Posted on Dec 26, 2014
MY MAJIC JACK IS NOT WORKING SO I THINK I NEED TO UP GRADE
Tonya, To help diagnose Magic Jack issues, check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
magicJack Live Chat
How to Fix Your MagicJack Problem
Magicjack Plus not working when plugged directly in the router SOLVED
Top Ten Frustrating Reasons Why Your magicJack Plus Wont Connect
Jul 22, 2016 | Cell Phones
How do I restart my magic jack after having my computer up dated? Phone # 559 416 8617
Majic Jack does not load softwatre in your computer. Restart your DSL router, then the computer with the Majic Jack plugged in to the computer abnd the phone. If you have internet working i.e. go to MSN and make sure it come up and the Majic Jack will talk to the internet then the majic jack central then you can doal.
Captain Jack
Sep 28, 2014 | Cell Phones
I cant use my majic jack because they ask me to pls connect to the internet and double click here error 3
Hi Jenny,
i've had the problem too some time back, try this,
first try it on another system which was not connected earlier if it works then follow as below
remove the Majic Jack and then go ahead and uninstall the driver and all just clean everything related to Majic Jack on your system, now connect the Majic Jack to preferably a different port than earlier, the drivers and all will be downloaded again and software will be upgraded all by itself and will install again
hope this helps
warm regards
Apr 19, 2014 | Computers & Internet
I can't register my new majic jack plus.
I had to change the magicJack email to an AOL account for some reason. Maybe this is why. It's been a while.
Oct 11, 2012 | Computers & Internet
I need a pnone # or email adress for majic custimer service, so I can retrive the proper info. that wil enable me to renew my majic jack device
Here's what I found. I suggest reading the ENTIRE page below:
http://broadband-nation.blogspot.com/2008/10/real-problems-with-magic-jack-is-majic.html
PO BOX 6785
West Palm Beach, FL 33405
Magic Jack Phone number: 281-404-1551
Billing MagicJack number: 561-594-2140
Feb 09, 2012 | Computers & Internet
I have TOSHIBA Satellite A 100 -534 and have a probleme fixing majicjack . please help
majic jack is not magic....if it worked before call them and have them send a replacement. been my experience majic(junk) jack is just that JUNK!!!
Jan 28, 2011 | Toshiba Computers & Internet
I have magic jack and am trying to use it for a medical device because I have a pacemaker and defibulater and it need to be monertered by a LATITUDE COMMUNICATOR.Can magic jack be used for the LATITUDE...
I have and use Magic Jack too..Does your Latitude Communicator just plug right into a phone jack with a regular phone cord? If it does, then it should work...You will have to always leave your laptop on and never turn it off because Magic Jack requires a constant connection...Plug your equipment into the back of your Magic Jack and then with another phone, call the company that monitors your pacemaker/defibulator and ask them to "test" your line to see if you will receive a signal from them through your Magic Jack...You will to have to plug it all in and then test or you won't ever know...When I plug my home phone into the back of my Magic Jack, I receive a dial tone just like it was connected to a home based landline phone
Jul 16, 2009 | Acer Computers & Internet
Magic jack problem
I have a magic jack and I can talk for 10 minutes only or less and then i hangs up , this problem is happening in three majic jacks with other friends
please advise
Jan 15, 2009 | Lands Phones
Magic jack?
magicJack requires approximately 80 kbps of bandwidth.. please contact your internet service provider and make sure you have at least that amount..you're not required to tell them that your using majic jack, but it shouldnt be a problem..Dial-up internet IS NOT enough to run Majic Jack, but "lite" DSL will work.
Oct 03, 2008 | Acer Aspire 3680 Laptop
Open Questions:
See all magicJack Two, 2 Magic Jack Plus Voip Phone With Questions
magicJack Two, 2 Magic Jack Plus Voip Phone With Or Without Computer In Box Logo
78 people viewed this question
Top magicJack Cell Phones Experts
gaucherre
Andrew Taylor
Andrew Taylor
Are you a magicJack Cell Phone Expert? Answer questions, earn points and help others
