NetGear DG834G Router Logo
Posted on Mar 03, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MAJIC JACK COMPUTER PHONE HANGING UP ON IT'S OWN
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
341
Points
Hi there, i have a magic jack and i'd like to use the voicemail the recorded voice is asking me for a mailbox assigned in my system, i'm usinf window vista and i dont know where to get a mailbox number please help!!!
Anonymous
Level 2:
Scholar:
  • Expert 104 Answers
  • Posted on Mar 03, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
104
Questions
0
Helped
23243
Points
362
Magicjack requires UDP ports 5060 and 5070 to be open. Try setting up port forwarding for those ports to the IP of your computer and see if it gets better.
If you have no idea how to do port forwarding, comment back and I will try to help you through that.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
I would like to know how to change my majic jack phone number.
  1. Visit your Magic Jack account-management page. ...
  2. Click on the "Phone Numbers" tab and select "View-Renew-Add."
  3. Click "Add a Phone Number" and choose your current number from the drop-down menu.
  4. Select the state you want to identify with your new telephone number. ...
  5. Choose if you want a U.S. number or a custom number.
More items...
How to Change the Magic Jack Phone Number ' Techwalla.com
https://www.techwalla.com/articles/how-to-change-the-magic-jack-phone-number how to change my majic jack phone number Google Search
Connecting the majic jack go phone to my closed caption phone.
Make sure both jacks are connected together.Some are not. Open all the wall jacks in the home to insure they pass the red and green wires on to the next jack. Connect any that are not, color for color. When all the jacks look like the wiring is OK then try the CC phone again.
I can call out on my Majic Jack Plus but cannot receive calls. The majic Jack is registered and set up on my modem.
This could be failure of the power adapter module.
Is your Magicjack plugged into the wall power thru a power adapter? Try bypassing the power adapter and plugging the magicjack directly into a USB port on your computer. If the magicjack work correctly now, then you have a bad power adapter module.
I had a similar problem. My Magicjack was plugged into a wall socket. First the dial tone became inconsistent, then I could no longer receive calls, then it died completely.
I plugged the MJ into a USB socket on my computer, and it then worked normally.
If you have a failing power adatper, it will continue to deteriorate, and it will eventually fail completely. The blue power on the magicjack will not come on when it is plugged into the power adapter, but it will illuminate when plugged into the USB socket on the computer.
Note: the computer must be on to power the magicjack thru the USB port.
Magicjack is aware of the problem and offers a replacement power adapter module. To contact them, go to www.magicjack.com and go to "support". They will ship you a new power module for about $5.50. Some people have reported that the replacement modules from Magicjack are no better than the originals and have had repeat failures.
Consider getting a power module from another source. There are lots of AC to USB power converter modules available on Ebay for only a few dollars. Search Ebay for "magicjack power adapter".
2answers
How do I restart my magic jack after having my computer up dated? Phone # 559 416 8617
Majic Jack does not load softwatre in your computer. Restart your DSL router, then the computer with the Majic Jack plugged in to the computer abnd the phone. If you have internet working i.e. go to MSN and make sure it come up and the Majic Jack will talk to the internet then the majic jack central then you can doal.
Captain Jack
Sep 28, 2014 • Cell Phones
I cant use my majic jack because they ask me to pls connect to the internet and double click here error 3
Hi Jenny,
i've had the problem too some time back, try this,
first try it on another system which was not connected earlier if it works then follow as below
remove the Majic Jack and then go ahead and uninstall the driver and all just clean everything related to Majic Jack on your system, now connect the Majic Jack to preferably a different port than earlier, the drivers and all will be downloaded again and software will be upgraded all by itself and will install again
hope this helps
warm regards
Old majic jack want to start new program
If you have an old Magic Jack, my 4 unit are 6 years old the company just really wants you to upgrade to a newer product no need to. Try removing Magic Jack completely from your tablet, restart unit, make sure to clean out all junk on tablet from Magic Jack you could try a program that cleans your tablet for you, but unless you know what to remove don't get technical just a standard clean up of old files, this is usually under apps, Magic Jack, then there will be a clear cash button, clear data, and uninstall.
Restart unit then do a fresh install of Magic Jacks new app for your type of tablet from Googles sight or Magic Jacks make sure if you have a Mac to install the Mac App and if you have an android tablet you install the Android App. This has been working for me. With the old Magic Jack you will need to do a fresh install when you get errors and crashes. I do it 2 or 3 times a year. Good Luck!!
Magicjack problems
Hi Dolores,
You need to contact Majic jack support and ask for a refund. Below is the link to initiate a chat to Majic Jack support.
Majic Jack Chat Support
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
2helpful
I need a pnone # or email adress for majic custimer service, so I can retrive the proper info. that wil enable me to renew my majic jack device
Here's what I found. I suggest reading the ENTIRE page below:
http://broadband-nation.blogspot.com/2008/10/real-problems-with-magic-jack-is-majic.html
PO BOX 6785
West Palm Beach, FL 33405
Magic Jack Phone number: 281-404-1551
Billing MagicJack number: 561-594-2140
Can you use majic jack with a lexmark 5600?
No it won't the magic jack works on your computer high speed Internet this model does not even have a modem so if you don't have high speed Internet on your computer you are waisting your time on the magic jack, also for your information magic jack is a rip off it is not the price they quote so I don't recommend it they add charges for every thing you add so the real price come to almost as much as using a cell phone unless you just use it for the 50 states.
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
