WHile testing it works good but when I start to quilt thread breaks and tension is messed up, ready to throw this out the door. HELP
Try changing to a different type of needle, like a top-stitch or embroidery needle. Sounds like the problem is an incompatibility of needle, thread, fabric sandwich.
Also, when threading the top thread, be sure to ALWAYS RAISE the presser foot!
Make your tests on the same fabric sandwich as you will be sewing.
Is this happening when you are free motion quilting? Do you have the right needle size, thread.
If you are talking about the thread on the bottom of the fabric being loose it is actually the tension on the top thread. The tension is too loose. You might want to check and make sure it is threaded properly and that the thread is between the tension disks. The slightest thing off will make it not operate properly.
You need to relax and take your time learning your sewing machine. Once you do that you will immediately know what to adjust or check.
