20 Most Recent Husqvarna Viking 1 Questions & Answers
How old is a Husqvarna Viking 5530. I have the manual and all the parts. It hasn't been used in many years and not sure if it is in good working condition. It was stored in the case.
The manual will usually have a copyright date or printed date something like ' 05/97 '. The best price I found was $171 on eBay. You can search for prices sold there. I also found this which makes it 50 years old. 1974 Warranty https://www.reddit.com/r/sewing/comments/cm6lrp/husqvarna_viking_sewing_machine_5530_what_should/ and this makes it 40 years old
Viking 5530 like new for $100 worth it??
patternreview.com https://sewing.patternreview.com > topic Jun 13, 2014 - But forget the like new thing, as that cannot be, as it's cam stack is 30 years old. But, they are not for the faint of heart either and ... Viking 5530 (or 55-30) -- desirable? - Pattern Review 6 posts Sep 12, 2009 viking 5530 sewing discussion topic @ PatternReview.com 5 posts Nov 7, 2011 viking 6440 vs Singer 401 sewing discussion topic ... 10 posts Apr 3, 2013 Is the Viking Designer 1 too old to consider? - Pattern ... 10 posts Feb 3, 2013 More results from sewing.patternreview.com More here https://www.google.com/search?q=husqvarna+viking+5530+sewing+machine ..
3/28/2024 6:30:05 PM • Husqvarna Viking... • Answered on Mar 28, 2024
Husqvarna Viking Designer 1 sewing machine. The touch screen is not working properly. Some areas not responding to touch.
Question edited for clarity. Question moved to model category. Try recalibrating the screen. Having said that, with the number of adverts for buying one, it looks like there is an issue. https://www.google.com/search?q=Husqvarna+Designer+1+touch+screen Power on the Designer 1. Press the "Reverse Feed" and "Sensor Pivot Foot" buttons simultaneously to enter the device's service menu. Press the "Cal" button on the display. Tap the "+" mark on the display to recalibrate the touch panel display.
How to Troubleshoot a Husqvarna Viking Designer 1 - eHow
Service Manual
Husqvarna Viking Designer I Service Manual [Page 10]
ManualsLib https://www.manualslib.com > ... > Service manual How to synchronize the touch area of the touch panel with the symbols on the screen. Get into the service program of the machine.
11/10/2023 11:13:42 PM • Husqvarna Viking... • Answered on Nov 10, 2023
Husqvarna Viking Designer Diamond Deluxe sewing and embroidery machine. Code for service mode on Designer Diamond Deluxe?
Question edited for a lot more clarity. Question moved from Watches to Husqvarna Viking. https://www.manualslib.com/manual/1054795/Husqvarna-Viking-Designer-I.html?page=6 Also found this Follow the instructions in the Installation Wizard. When asked to enter your Installation Code, enter the following number: 9200. and all this
I am needing a service code password for my Husqvarna
JustAnswer https://www.justanswer.com > small-appliance > ciwzd... Jun 18, 2019 - I am needing a service code password for my Husqvarna. I am needing a service code password ***** my Husqvarna Designer Diamond sewing machine. 1 answer · Top answer: Just go to the tools screen and look at the timer which will give you the hours and minutes ...
SOLVED: Service Menu For Husqvarna Designer SE
Fixya https://www.fixya.com > ... > Husqvarna > Designer I Hi SewTechWayne, do you happen to have the latest pass code? 5031 is no longer working on my machine. Thanks!
User's Guide
Husqvarna VIKING https://www.husqvarnaviking.com > ClientSite When asked to enter your Installation Code, enter the following number: 9200. 5. In the 5D™ Configure Wizard under MyMachines select your machine type: ... 140 pages
Husqvarna Viking Designer I Service Manual [Page 6]
ManualsLib https://www.manualslib.com > ... > Service manual Husqvarna Viking Designer I Manual Online: Service Program. ... Press Handling Get into the service program of the machine by pressing the reverse feed... ..
8/23/2023 5:49:23 PM • Husqvarna Viking... • Answered on Aug 23, 2023
I have a Husqvarna Viking Optima 120 sewing machine. It was working fine, then out of the blue the bottom thread is bunching up?
Question edited for full 'make model (what it is)'. Question moved to maker category. You either have a threading issue, or a tension issue, or both issues. Read the Article and watch the videos. By thread tension, we mean the amount of thread that can pass through the machine to create the stitch. The more thread in the stitch, then the looser the stitch. The less thread, then the tighter the stitch. Top thread tension is controlled by a dial on the machine's thread path. Sep 11, 2018
Adjusting tension on sewing machine - Artisan Stitch
5/2/2023 12:27:28 AM • Husqvarna Viking... • Answered on May 02, 2023
Husqvarna Viking Classica 100 sewing machine Service Manual please?
Question edited for clarity and correct order of make model. Question moved for Cars and Trucks category. Unfortunately there isn't one. Owner manual only. Service agents are factory trained, and have online resources, but generally they already know their way around inside all machines. https://www.google.com/search?q=Husqvarna+Viking+Classica+100+service+manual If it is stuck in reverse, there is help on Fixya from 2012. ..
3/15/2023 11:41:18 PM • Husqvarna Viking... • Answered on Mar 15, 2023
2answers
Viking Husqvarna 1610 sewing machine won't go in reverse
Check with an authorized Husqvarna Viking dealer. Check Husqvarna Viking website for dealer closest too you.
1/12/2023 5:02:41 AM • Husqvarna Viking... • Answered on Jan 12, 2023
Feed dogs go up and down but not forward and
Sounds like the feeding mechanism is messed up. If turning it on and off does not resolve the issue, you'll need to have it serviced by a certified Husqvarna Viking service technician. If you are the original owner it may still be under warranty. SE's have a 5 year electronic parts warranty and 20 year mechanical warranty. However, you will need to have it serviced by a Husqvarna Viking dealer. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
9/16/2022 2:30:13 PM • Husqvarna Viking... • Answered on Sep 16, 2022
2answers
Pressure foot too high cannot be lowered
sounds like the pressure foot lifter is stuck. Usually the height of the pressure foot is a manual adjustment done by a service technician. Suggest that it be serviced by an authorized Husqvarna Viking Dealer. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
2/15/2022 9:45:56 AM • Husqvarna Viking... • Answered on Feb 15, 2022
3answers
Changing light bulb on viking designer 1
when one faulty, both do not work. replace faulty one & both will then work.
1/25/2022 7:11:51 PM • Husqvarna Viking... • Answered on Jan 25, 2022
What is the symptom of a broken hoop?
Sounds like you might be having problems with the machine not wanting to start sewing an embroidery pattern or not recognizing the hoop size. If the former, and the embroidery is full size (say 100x100mm), try reducing the embroidery slightly (say 98x98mm). If the latter, your embroidery unit may need slight adjustment to correctly identify the hoop. Its not an elaborate adjustment but you will probably need a profession to accomplish it.
12/2/2021 10:49:22 AM • Husqvarna Viking... • Answered on Dec 02, 2021
Husqvarna classica 100 stuck in reverse
I found a Classica 90 that wouldnt reverse. When I took it apart I realized the stitch width mechanism was stuck.
The reversing mechanism manipulated that part to reverse. Problem- mechanism and shaft super stuck. I took it out and forced the shaft to turn and lubed it with a general thin oil. I didn’t know the mechanism; or anything about sewing machines. The give-away was a spring connected to the mechanism. Since it was stuck the spring didn’t seem to have any function..... until I realized it had to be moving. Hope it makes sense.
One screw top back to removed cover. It glides up.
1 screen behind reverse button removes front cover. Also slides up. You reach from behind to get the mechanism out( 2 screws holding small shaft. 2 springs off also. )
Front cover needs to come off to dissemble stitch width turning nob. Has to come of to release the reversing/stitch width mechanism.
It’s not as difficult as it look. You might need a small plier to put springs back in place
Foto shows the stitch width mechanism. The front spring is attached to the part that was stuck.
11/7/2021 8:41:59 PM • Husqvarna Viking... • Answered on Nov 07, 2021
Husqvarna 2000 series (64 40) How to remove
Hi, to remove the handwheel on a Viking 6440 you just need to take two screw drivers, one on each side, and gently pry the handwheel off. Nothing else is keeping it attached. Many of these are just stuck a bit and need gentle prying.
Good luck.
Rick
8/6/2021 1:17:03 AM • Husqvarna Viking... • Answered on Aug 06, 2021
2answers
My Husqvarna Prism 990 only sews in reverse.
You could have an electronic problem on the main printed circuit board or in the feed length stepper motor. You may also just have a bound section in the feed mechanism. I don't think there is a cure all answer for this problem.
A 1/2 second hesitation between depressing the foot control and motor response is very common in these machines
If your husband lubricated the bushings on the upper and lower shafts of your 990 I recommend that you have him remove all of the lubricant possible and keep your fingers crossed. The 990 is a self-lubricating machine and applying machine oil to these bushing will probably cause them to seize. The 990 should never be lubricated in many of the places you would lubricate many machines. Hopefully, you haven't done irreparable damage.
3/28/2021 2:55:20 AM • Husqvarna Viking... • Answered on Mar 28, 2021
The 3-D embroidery system seems
USB Designer 1s use Disk Manager, just like their floppy disk sisters, but it needs to be Disk Manager USB. New USB Des1s came with this program on a CD, and this software was also included free when a floppy disk Des1 was converted to USB. If you bought your D1 USB new, check the disks that came with it - one should be Disk Manager USB. If you purchased the machine second hand, contact the seller and ask for the program. It is a free standing program and you don't need a dongle. Check your 3D software - you might already have what you need. Open 3D, click down arrow for Accessories (far right-hand side) - what does your Disk Manager say? If it says Disk Manager USB you are okay to go.
I am not 100% sure of this, but I think that maybe the last update for 3D software (version 7.25) might have included Disk Manager USB. Go to the Husqvarna website and make sure your 3D is updated to the latest version.
If none of the above helps you, there is always the cheap cost embroidery software alternatives: Embird or Sew What. I believe they can write to Designer 1 USB sticks now.
2/1/2021 6:53:02 AM • Husqvarna Viking... • Answered on Feb 01, 2021
2answers
When I try to start my 4D embroidery software for
The author is incorrect regarding all of the uses of the HASP software/drivers. In the case of the sewing/design software being at issue with this person, she is dealing with a HASP hardware dongle which is the license control mechanism of a software product which absolutely *MUST* be installed on the personal computer or they cannot use the software. At all times, when the software is used, the hardware key and the HASP software must be running and the HASP license manager must be running as a service under services.msc
For quiltin_mama:
I have been struggling with this issue for my mother as well and have not come up with a final solution but I believe ours is one of damaged dongle or erroneous registry entries. I suggest the following actions:
1) lauch services.msc (click Start -> Run -> and type services.msc <enter> in the box) and look down the list for HASPLM?.EXE (I don't recall the full name). Verify that it is set to start automatically (right click on the item, choose properties, set "Startup Type" to automatic.
2. If you are using Windows Firewall, you need to add exceptions to the firewall: Control Panel -> Windows Firewall -> Click the "Exceptions" tab at the top.
You will need to add an exception for some of the 4D software applications. Now, I don't know which ones actually talk to the HASP, so what I suggest is: Click Add to create a new exception, and then click the "Browse" button to the lower right. Navigate to c:4d embroider\ (assuming you have the default directory) and then select the first 4D***.exe you find on the list, and click done. As I recall, there are 4 of these apps and you need to do this for each of them. Down the road, if any of the other parts of the software suite fail because they can't communicate, come back here and add the *.exe to the exception list.
Next, you need to exempt certain TCP/IP ports from the control of the Windows Firewall. If you download and install the firmware update from Husqvarna's site which they say is included in the 8.1 upgrade, the very last screen of the process, after doing all the main work, it will tell you to open a specific software port. I can't remember which port that is, but as I recall it was 14xx. Run this update and write down that port.
Back to the firewall exceptions list, now create two entries for this port: the first is for TCP port of that number and the second is the UDP port for that same number. Don't worry about why, but both appear to be needed. When adding the exception to the port, there is a button at the bottom left which says "scope". Click that and make sure that the top radio button of the 3 choices is the one selected.
Second, I made an interesting discovery while searching and trying to find the port number I mention above. There is another port which is listed as the "default" port for the Alladdin HASP software/dongle we are dealing with, and that is port 475. Please add exceptions (both TCP and UDP) for that port as well.
Finally, make certain that you have the latest HASP drivers from the ! HUSQVARNA ! site for Windows Vista and then apply the various 8.x updates to the 4D Embroidery software ! IN ORDER!, starting with 8.1, then 8.2a, then the 8.2b, then the 8.3, and the second 8.3(b?). (The 8.2 version has a 1 either before or after the '2', I don't recall which, the important thing to remember is that there is a 2a and 2b version and to do the 2a version first)
As you install these updates, BE VERY CAREFULL to read any warnings. I am told that some of the updates do not work with/will break under different versions of Windows. I haven't seen this myself as I haven't run them, but a dealer told my mom that one of the updates was her problem and that the update specifically said not to install it if you had Windows version (X). Unfortunately, not have the software myself, I cannot confirm or deny this.
There you go, I hope these steps help. One other piece of information: when (re)installing the 4D software and/or the updates, disconnect the computer from the internet and shut down any antivirus, antispyware, antimalware, and firewall software you might have running. After completing the installation, be certain to *REBOOT* the computer and logging in so the AV software is running before you again connect to the internet. I hate to say it, but all it takes is a matter of seconds before a worm can find its way into an unprotected computer to infect it. A couple of years ago one of the test organizations did that with a PC and it was fully under the control of malicious people on the internet in less than 2 minutes.
Best of Luck,
Mike
11/22/2020 11:51:25 PM • Husqvarna Viking... • Answered on Nov 22, 2020
I am trying to get
Hi Geoff, The H0033 error is a known issue, but it is nothing wrong with your software or the physical dongle !
The issue is related to the Anti-Virus/Firewall software settings in your computer. This is why it can work on one computer and doesn't work on another.
There are unfortunately a lot of different firewall software products available on the market, so it is not easy to give exact steps to correct this for each and every available product. You need to tell your Anti-Virus program to allow the software to open.
Herewith is a way to change the settings on Norton 2008. If your are using a different Anti-Virus and understand the logic behind it, you should be able to change the settings:
Norton Internet Security 2008
1. Open Norton Internet Security 2008
2. Click on the Options link on the bottom left of the screen.
3. Click on Norton Internet Security from the drop-down list.
4. The Norton Internet Security Option screen will open.
5. Click on the Personal Firewall link on the left of the screen.
6. Click on the Program Control link.
7. Select the hasplms entry.
8. Change the Access drop-down list from Custom to Allow.
9. Click Apply then click OK.
11/22/2020 11:48:13 PM • Husqvarna Viking... • Answered on Nov 22, 2020
2answers
I have a very old viking - feed dog problem
The older 6XXX series are the best machines Viking ever made. But they have one flaw - if the button hole mechanism is not regularly serviced and used, it will eventually stick and the machine will only sew in reverse. This can also happen if you turn the knob backwards when in button hole mode.
I always tell my customers to make a few button holes every time they use the machine. This helps to keep the mechanism free and working between servicing.
Unfortunately the fix is not a DIY consumer project. It requires knowledge and expertise in disassembling the machine and re-aligning the parts. Expect to pay anywhere from $25 to $75 in addition to the regular servicing fee.
Steve P
Minneapolis
aka "The Bobbin Doctor"
11/13/2020 7:34:25 AM • Husqvarna Viking... • Answered on Nov 13, 2020
Has anyone had an issue with the husqvarna 600e continuously breaking needles?
Needle breaks 1.the needle is damaged 2.the needle is not correctly inserted 3.wrong size needle for the fabric 4.the wrong foot is attached 5.the needle clamp screw is loose 6. Top tension is too tight7. machine could also be out of time
7/11/2020 11:25:22 AM • Husqvarna Viking... • Answered on Jul 11, 2020
5answers
Bobbin Case Spins - in Huskystar C20
I had this problem when I first bought my machine. I took it in and they told me it was a recall problem. All the machines were having the same problem. They fixed it and I have not had the problem since. I bought mine at a Joanne fabrics. Hope this helps.
7/5/2020 9:23:00 PM • Husqvarna Viking... • Answered on Jul 05, 2020
Sewing Machines Logo
1,346 questions posted
Top Husqvarna Sewing Machines Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Husqvarna Sewing Machines
Most Popular Question
3 d embroidery system seems
  • Sewing Machines
