Could be a shorted inverter blew fuse and unit dead. Or bad fuse holder got fuse hot and melted fuse so now unit dead. Must check fuse first and if bad replace and try, if it blows as soon as it tries to heat probably bad inverter. If it works for a long while then quits maybe bad fuse holder not grabbing fuse tightly making it over heat. So then bad by temperature not amperage.
SOURCE: panasonic microwave s254bf stopped working
A microwave can be dead for many reasons. If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again. If it's random, it may be a bad connection, usually on the control board or fuse holder. If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor. If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer. If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven. At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information. See our listing here on FixYa: http://tinyurl.com/yzjozk
SOURCE: microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit. The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
SOURCE: Panasonic Microwave NN-A770S getting hot on right side externally
Is it normal for a Panasonic nn-c994s to cycle the fan/inverter
when using combination cook?
16 sec off 6 sec on.
Everything else seems to be working
light, timer counting down, heating food, turntable turning
SOURCE: Microwave LG LMV1630 st is totally dead after power outage
yes it s a large ceramic fuse and you have to remove the outer cover to access this. it will be on the top of the M/wave frame either front L or front right. Cost is about $40.00
Please rate our help to keep the sevice online
