I cleaned the thermistors in the fuser which were dirty. I tried using the instruction for Ricoh, but using either clear or reset, then 107 and holding stop did not work to get me into the next screen. SOLVED: Use Reset - 107 - Clear. NOW YOU ARE ON YOUR OWN. I believe following the rest of Ricoh instructions might work, but we had a service tech lead us through.
SOURCE: Minolta Error code C0500
1. Test Mode Operations
• The Test Mode is performed from the copier’s Tech. Rep. Mode.
1-1. Entering the Tech. Rep. Mode
1. Press the Utility key.
2. Touch [Total Check].
3. Press the following keys in order: Stop → 0 → 0
→ Stop → 0 → 1.
NOTE
• Be sure to keep the display procedure for the Tech.
Rep. Mode from any unauthorized persons not
involved with service operations.
4344S504CA
link to a service manual that explains tech mode
SOURCE: How to clear error code SC571 on Ricoh 1232c copier
See thread I left you this morning on this. I hope it helps.
Press the yellow button. Press the 107 keys. Press and hold the red clear button for a few seconds until the service mode screen appears on the LCD display.
SOURCE: Lanier LD060 has a SC541 Error Code
Troubleshooting tips:
Enter SP Mode by holding down "up" and "down" arrow for 10 s then you press "enter"
SC 541 Heating roller
thermistor error
The temperature measured by
the heating roller thermistor
does not reach 7 °C for ten
seconds.
Loose connection of
the heating roller
thermistor
Defective heating roller
thermistor
Defective BCU
1. Check if the heating roller thermistor
is firmly connected.
2. Replace the fusing unit.
3. Replace the BCU.
Controller
errors CTL The error has occurred in the
controller.
See .Troubleshooting Procedure. in
the table.
A
The error involves the fusing unit.
The machine operation is disabled.
The user cannot reset the error.
Turn the main switch off and on.
Reset the SC (set SP5-810-1).
Enter the SP Mode by holding down "up" and "down" arrow for 10 s then you press "enter"
Also, check info on this link:
http://helpdeskgeek.com/how-to/ricoh-aficio-cl7200-printer-sc541-error/
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: How do I get to Tech Rep Service Mode on Minoltas to clear C0500 error code?
I need to know m/c model
SOURCE: service mode
Press the “Up/Down arrow” keys together for about 5 seconds, and then press the
“OK” key.
“SYSTEMver x.xx/ 1. Service” appears on the display.
The machine automatically goes off line when you enter the service mode.
enter SP 5810 and reset the SC 543 **** if again appears please do not reset it again because you may do bigger problem and damage more part than ware damaged in first place .
The SC code says that the termistor is damaged so check on the fusing unit dose the termistor is standing in good position or has dirt on the surface of he termistor.
RATE ME IF THIS HELP YOU
