20 Most Recent Lanier 5235 Printer Questions & Answers
The waste toner is contained inside the belt unit that is mounted on the inside of the right hand door. Remove the screws that hold it together and dump it. Very messy so be careful. The message will go away by itself.
Lanier 5235... • Answered on Dec 14, 2014
Try removing the toner cartridge and gently cleaning the electrical contacts for the sensor. Sometimes they get toner residue on them and give false readings.
Lanier 5235... • Answered on Aug 06, 2012
U14 is a user code for waste toner full.
Open front cover and you will see a clear plastic bottle at the bottom of the machine; lift this out and dispose carefully of waste toner (do not reuse). When fitting back into machine, make sure that inside of bottle is clean as the detection sensor looks through the bottle to see if it is empty and if toner is covering inside of bottle, the message will remain.
Lanier 5235... • Answered on Jul 26, 2011
Your Lanier is made by Ricoh and is a model Aficio 355. The drum and drum cleaning blade is still available and not too expensive at about $200 for the pair. You can find these with all the related info at precisionroller.com Great people to deal with and I order a LOT of stuff from them.
Their part numbers are P8150 for the drum and C5950 for the cleaning blade.
Good Luck and Thank You for using Fixya.
Lanier 5235... • Answered on Jan 19, 2011
why the paper come white when i print somthing
Lanier 5235... • Answered on Mar 07, 2010
Could be the exposure lamp or the lamp control board. You will need a service call or find some place to buy used parts and just swap them out.
Lanier 5235... • Answered on Feb 10, 2010
the green roller is your drum,(not meant to be touched) a blade cleans it (like a windshield wiper does sot of ) sounds like you lost charge voltage, you need a service call, sorry
-Carl, please let me know if this helps.
Lanier 5235... • Answered on Oct 27, 2009
Greetings,
usually this would be either a cartridge or a fuser.since you changed a cartridge and it's still there.most likely it is the fuser.
you could double check by doing a half stop test.start a print from tray 1 and when the trailing edge of paper is just entering the machine,open the printer to stop print and take out the cartridge,open it's shutter and look at it's drum and the paper just underneath.if the issue ios not at either of those places,then probably the fuser.
if you take out the fuser ,you may be able to see an issue with a fuser roller.like a tear or other anamoly.
Also More than likely your fuser is peeling. Pretty easy to check...power down printer and pull rear door then unlatch the fuser and look at the fuser rollers...more than likely the bottom roller is peeling on one side...you'll know it when you see it...
Regards,
TechSup1
Your duplex is the big box on the right side of the machine push the back side shut against the machine and try again
Try a new staple cart. as the staples are not advancing. -Carl
Lanier 5235... • Answered on Jun 23, 2009
The PCU is behind the right door, remove the waste toner and its the one on the left.
-Carl
Lanier 5235... • Answered on Jun 22, 2009
If when you open the rt. door are the streaks on the drum unit? If not remove the 1 screw and slide the fuser out and check there
-Carl
Check your photo conductor (drum) unit. This is often caused by an old or light damaged unit.
Lanier 5235... • Answered on Dec 22, 2008
I discovered the magenta pcu roller which I had replaced was damaged. Thanks for your help.
Lanier 5235... • Answered on Apr 01, 2008
There are site here that say they have it. First on is a full description by Wichita State Court. https://www.google.com/search?q=lanier+lcr-5+manual ..
Lanier Office... • Answered on May 20, 2021
23 questions posted
Top Lanier Office Equipment & Supplies Experts
George Mclaughlin
ADMIN Canada
ADMIN Canada
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Lanier Office Equipment & Supplies
Most Popular Question
locate drum old lanier 5235
  • Office Equipment & Supplies
