SOURCE: Nothing works
try taken face plate off if detachable then put back on sounds like the face plate clip might be weak and or missing spring inside
but if face plate stays attached just need to clean and put back on right to deck no easy way to say that
SOURCE: I am getting no Power to my DEH-P5800MP
check your fuses in your fuse box you may have blown one
SOURCE: Pioneer DEH-P5800MP CD Player not powering on.
did you try the fuse behind the wireharness. if so check the yellow wire and the red one for power. also check if you have ground on it. if you want to make things simpler try to connect the black wire to the battery neg. and the yellow and red together on the positive of the battery and see if it turns on.
