Dehumidifiers Logo
j
john peters Posted on Nov 16, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My pifco 440011P dehumidifier switches on but the small green light is constantly flasing on/off.there is no sound coming from it at all.can you help?
schwaa44
Level 3:
Master:
  • Master 252 Answers
  • Posted on Nov 16, 2016
schwaa44
Master
Level 3:
Master:
Answers
252
Questions
0
Helped
127382
Points
1401
I can't find the manual for this, but you can e-mail pifco directly and ask for the manual at:
[email protected]
PIFCO Heating Cooling Floorcare more
Does not shut off when tank full, water leaks all over the floor if I don't watch it constantly
Sounds like the float valve inside tank may be stuck in closed position. Calcium buildup is very common. Good luck Juliana. Unplug and empty tank of any water and look for the float valve it should be near top of tank. Use a small bucket and mix vinegar and water and brush. Scrub that valve. Clean it up
I have a delongji DEM 10 dehumidifier and it keeps switching to pause, I have cleaned filter switched off for a while but it still won't come on
follow this steps and fix it. God bless you
Unless you are licensed and qualified professional, do not try to repair a dehumidifier by yourself. If your unit is running constantly yet there is no water in the tank, try lowering the temperature control. If the problem persists, there may be a problem within the refrigeration system. You may need to pull the filter and clean it. Also try wiping off the unit itself. When the water tank is full, the unit will shut off and will not run until the tank is emptied. The dehumidifier shuts off by a safety switch in the back of the unit. If the switch is not working properly, you may try manually pressing the button or slightly bending the switch.
    Motor If the fan motor is damaged or will not work, no cool air will be coming out of the dehumidifier. The unit, however, may still run. You may need to replace the motor. If the coils in the back of the dehumidifier constantly freeze, try turning off the unit for an hour or re-locating the unit to a higher position to allow the room to heat up. If your water tank is constantly full and you are emptying it on a daily basis, you may have a water leak somewhere in the room with the dehumidifier.
    Unit wont run but lights up. It reads low humidity even though its high
    First, make sure the reservoir is empty. If you plug the unit in and see a green power light, but the unit won't run, make sure the reservoir is properly inserted. Many dehumidifiers have switches or sensors to make sure that the reservoir is placed so that it won't leak. Look for these sensors and make sure the reservoir is engaging them. If your dehumidifier has a float or switch to indicate a full reservoir, make sure this switch isn't being tripped accidentally.
    Good luck.
    2helpful
    2answers
    My DeLonghi Portable Dehumidifier Model DEM10 has stopped working. It doesn't make the same noise when you turn it on anymore i.e the slight refridgerator sound. Does this sound like a repairable problem...
    Good luck.
    2answers
    The red indicator light just flashes when i turn the unit on. Whats wrong?
    The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
    If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
    Good luck.
    Light saying bucket is full is on all the time and unit is not working
    Good luck.
    4helpful
    Dehumidifier running but not producing water
    Sounds like your relay switch isn't connecting....
    Newair ADS-300 Dehumidifier
    Top Dehumidifiers Experts
    ZJ Limited
    ZJ Limited
    ADMIN Andrew
    ADMIN Andrew
    Are you a Dehumidifier Expert? Answer questions, earn points and help others
