SOURCE: power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
SOURCE: Can anyone tell me if the 12 volt powersupply is 12 volt AC or DC ?
Model HER-48-12010
P/N: 68300021-0013
AC Input
DC Output
SOURCE: NPS-200PB-73M
SPECIFICATIONS:
Dimensions 5.9"W (150mm) x 3.4"H (86mm) x 5.5"D (140mm)
Special Features Dell Proprietary Main ATX & 6 Pin Auxiliary Connectors
AC Input 100-120V/7A 60Hz 200-240V/3.5A 50Hz
DC Output Voltage 3.3V 5V12V
Total Output Max Load 200W
Regards.
SOURCE: input voltage ?? lost power supply WHP-150C
the adapter is a thomson output is 19v-200ma--neg polarity
SOURCE: Re the part DC-9v Adapter. Is this for use as a AC
IF it says do not do it then dont do it? Also even if you break it its a lifetime warranty so if you wanted to take your chances
Hi Guy Robinson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What do you want to know
