If the tire is not damaged and will hold air then you may be able to reseat the tire. One method if you do not have proper tools or do not want to go to a tire shop is to lubricate the sine of rim with a dish soap solution to make it slippery. Take a ratchet holddown strap and run it around the tire and tighten it to force the beads of the tire onto the rim. Then use a compressor to inflate the tire and the beads should snap back onto the rim. Once that is done, remove the strap, remount the tire on the tractor and inflate to the proper level.
