Washing Machines Logo
Marquis Posted on Sep 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why do my admiral washer lid won't lock - Admiral Washing Machines
The Vanguardian
Level 3:
Master:
  • Master 531 Answers
  • Posted on Sep 27, 2016
The Vanguardian
Master
Level 3:
Master:
Answers
531
Questions
0
Helped
180719
Points
2974
BRAND, MODEL, NUMBER, PLEASE!!!!
We're not the psychic hotline!!!
We have no damn clue if you don't give us enough information about your product!
Marvin
Level 3:
Top Expert:
  • Admiral Master 85,242 Answers
Marvin
Admiral Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29060381
Points
266281
Need the model number.
5 Related Answers
Anonymous
  • 333 Answers
  • Posted on Nov 28, 2008
SOURCE: How to bypass Lid Switch Admiral Washer
The only way to bypass this switch is fist pill the plug, gain access to the switch from under the hood. put a jumper wire on the 2 wires on the switch. that will do it. I hope this helps you out.
nomess
  • 343 Answers
  • Posted on May 24, 2010
SOURCE: My admiral washer Model #LNC 676OB71 continues to ...
If the water continues to run, even when power is off at the wall switch it's likely that the water inlet valve has failed...When power is cut they should shut off!..Replacing the inlet valve is a simple and common job...Good luck....Nomess
richroth
Richard Roth
  • 9472 Answers
  • Posted on Nov 02, 2012
SOURCE: Washer Senses one time then the lid lock blinks and the lid unlocks! It won't start or fill
Here is the service manual for your machine. Look at 6-4 for diagnostic mode.
Anonymous
  • Posted on May 07, 2013
SOURCE: my whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Lid switch was flashing on/off now won't even light washer fill and pumps out but won't wash or spin HELP
iliabichin
Ilia B
  • 37 Answers
  • Posted on Jan 20, 2015
SOURCE: Admiral washer ATW4676BQ 3.6 cu ft lid will not lock
check the lid switch and striker
My admiral washer does not work on wash cycle. It will rinse and spin on any cycle but wash
hi Marilyn.
this is what i have found but not sure if this will help you out,if not go to the link at the bottom and see if it helps you out.
Step 1
Make sure the washer's cord is plugged in to a functioning outlet if the Admiral washer won't fill with water. Check your circuit breaker to make sure the power is on and reset it if necessary. Reset the dial and start the washer again. Turn both of the washer's faucets on to full power. Untangle any inlet hoses to remove clogs. If this doesn't work, your hose filter screens could be clogged. Disconnect the hoses from the washer and clean the screens of any residue.
Step 2
Close the washer's lid completely if the Admiral washer will not agitate. The washer will not start if the lid is open. Restart the washer by setting the control dial to the desired cycle. Momentary pauses during cycles can be expected. You may need to wait a minute or two to see if the washer starts. Check the circuit breaker to make sure the washer is getting power. Reset the circuit breaker if necessary.
Step 3
Check and reset the circuit breaker as above if the Admiral washer will not spin or drain. Untangle any of the washer's hoses to allow water into the machine. Check your drains for clogs that may be preventing water to move into the washing machine. Close the lid and restart the washer. The washer will not start if the lid is not completely closed. If there are excessive soap bubbles in the washer, the washer may have locked up because of this. Wash the load again without adding detergent.
Step 4
Rearrange the laundry so it is evenly distributed if the Admiral washer stops or if laundry is still wet at the end of a cycle. Untangle any laundry from the center post in the wash tub. Select the correct water level for the amount of laundry. Select a normal spin cycle for jeans, towels or other heavy loads. Close the lid and start the washer.
Step 5
Check the hoses to make sure they are tightly connected to the Admiral washer if it leaks water. If they are loose, tighten them with a screwdriver. Make sure the drain hose is secured to the drainage area. Avoid putting too much laundry in your machine or soaking laundry for over 30 minutes.
Step 6
Make sure the Admiral washer is on a level plane if it is excessively noisy. If it is not on even ground, move the washer so that it is level. Remember that some washer noise is normal. Thin floors can cause the washer to vibrate and move about and the noise level may rise and fall depending on the speed of the cycle.
admiral washer does not work on wash cycle Google Search
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
www.repairclinic.com/.../Washing-Machine...-/Amana-Washing-Machin...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin · Washer is making loud noise ...
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
2answers
Washer fills but will not spin and shuts off after a few seconds
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the lid switch assembly, you jump it to test it. If the lid switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
6helpful
3answers
Opening cabinate? Admiral washer AAV 7000 AWW
Soak the lid around were the rubber bumpers stop the lid from letting it slam down, mine had become almost glued, I really had to pull hard to unstick them good luck. I have never seen a top lid with a lock.
Top Admiral Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
