Question about Whirlpool WTW5550XW Energy Star Qualified Cabrio High- Efficiency Top
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Lid light flashes even after power button is turned off
Posted by katrina houpt... on
  • Anonymous Mar 24, 2014
    Power button won't work
Craig Benton
    New Friend:
Lid switch was flashing on/off now won't even light washer fill and pumps out but won't wash or spin HELP
Posted on May 07, 2013
  • Whirlpool Master
  • 17,130 Answers
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Posted on Sep 04, 2012
5 Related Answers
Anonymous
  • 82 Answers
SOURCE: Cabrio washer want start.
leave the door open and try it again if it does the same thing as before the door lock has gone
Posted on Jun 27, 2009
emissionwiz
Marvin
  • 85239 Answers
SOURCE: where is the reset button on Cabrio dryer
there is no reset, unplug the unit for 5 minutes, if it still won't start you have a CCU problem, that is the central control board.
Posted on Oct 06, 2009
Testimonial: "Hey there- Thank you so much for your help. I think I have a central contol board problem. I will have the repair man out tomorrow. Denise"
rickead1
Rick Ead
  • 1998 Answers
SOURCE: door locked, won't turn on. won't reset
Remove the bottom panel which would give you access to the pump area if you look up along the side that the door lock is on you will see a cord with a loop on it pull this cord and the door would open. The panel must be removed in order to locate this pull cord. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks Rick
p.s if after you open the door and you were to leave the unit unplugged for 7 minutes if the error did not go away or if the door once again locked up you would have no choice but to replace the door lock assembly on the unit Thanks again Rick
Posted on Jul 04, 2011
Testimonial: "Good advice fast! Thank you so much for your time and expertise!"
Anonymous
  • 572 Answers
SOURCE: The lid will not lock on my Whirlpool Cabrio
id change the door switch
Posted on Feb 06, 2010
Prakash R
  • 1382 Answers
SOURCE: Will start the wash cycle and DL come on and light
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Posted on Jul 28, 2010
Whirlpool cabrio washer, I try to start a load by pushing the start button, the lid lock clicks shut like normal but then the light starts blinking and the washer wont run.
If it's the lid locking light that's flashing, then the Lid Latch assembly needs to be replaced. It's latching, but the switch inside it isn't working and doesn't recognize that it's latched.
They have the part and a video on how to fix it at this parts company.
http://www.appliancepartspros.com/whirlpool-latch-w10404050-ap5263307.html
Oct 03, 2016 | Whirlpool Washing Machines
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Nov 26, 2015 | Washing Machines
What if the lid lock keeps flashing
it flashes if the program is in pause mode
press the start button again to get the program to start
Nov 08, 2015 | Whirlpool WTW6400SW Cabrio Washer
Lid locked light on, will not release
The lid lock light won't stop blinking. - Fixya
www.fixya.com/.../t14714916-lid_lock_light_won_39_t_stop_blinking
Oct 21, 2012 - The lid locked keeps blinking and I can not start a cycle. - WhirlpoolLSB6200KQ Top Load Washer question. ... Whirpool cabrio wtw5500xw top loadwasher will not start lid light flashes then goes out and into flashing pause ...
Whirlpool washing machine_ lock light flashing_ nothing ...
? 1:53
www.youtube.com/watch?v=zrV9w6Z5LAU
Mar 3, 2012 - Uploaded by briantaylor62 Whirlpool washer wont start a cycle, lid does lock and the locklight ... a cabrio as well that just has the lid lock flashing and nothing happens , I ...
Flashing Lid Lock Light: How to Troubleshoot Errors on Your ...
? 1:23
www.youtube.com/watch?v=nttHsAX2_OM
Mar 27, 2015 - Uploaded by searspartsdirect
The lid lock light on VMW washers, made by Whirlpool, Kenmore and Maytag, will flash whenever there is a ...
Oct 12, 2015 | Washing Machines
My Whirlpool Cabrio washer wtw555oxwo turns on, lid locks, then the lid lock light starts flashing and the machine does nothing. Just replaced the lid lock, but nothing has changed. Any suggestions?
adjust the lid lock switch?? seems to me that lid lock mech is not moving far enough to properly be sensed by switch
if machine is over 8 months old id suspect rust in lock arm as cause
Jul 22, 2015 | Whirlpool Washing Machines
I have a Whirlpool Cbrio top load washer. it won't start it's cycle. Once it senses the load, the lock lid light flashes and it does nothing. can this be fixed?
I would say that the lock has failed. Either the lock itself or maybe the pin or latch that fits into it when you close the door may have cracked / broken. If the machine thinks the door / lid is still open, it wont let you start it.
Jan 03, 2015 | Whirlpool Washing Machines
Washer will not start. Start button flashes but lid is not locked
If the lid lock light is flashing, that is an error. If the lid doesnt lock it won't do anything. There is a diagnostic test that you could do to prove it if you are good with electronics and ohm meters. Most tecks would probably tell you to replace the lid lock assembly. That is probably the cheapest part. The only problem is that without the diagnostis test it could be somthing else. But first check to see that the wire that comes from the lock is securely plugged into the control board.
Oct 21, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool WTW5550XW Energy Star Qualified Cabrio High- Efficiency Top Logo
3,470 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
