SOURCE: goodmans ld 26022
I found two solutions to tripping:
#1: http://www.e-repair.co.uk/faults/GS017425.HTM
Replace line output transistor TR16. Resolder capacitor C68 as will blow transistor again if not resoldered
#2: http://www.eserviceinfo.com/repair_tips.php?search_rt=W280NS
Dry joints C68 & C71 & LOPTr slightly leaky
Looks like it would be worth looking at the board for bad solder joints and burnt components.
SOURCE: My TV is going into standby mode whenever it is turned on
My screen turns black and the TV goes into standby mode (I get an Amber Light) within 3 seconds after turning the TV on.
SOURCE: Standby mode
I have the same television. Mine would shut off and turn back on every 30 seconds. Even though the LAMP light wasnt coming on in the front of the set, I replaced the lamp with a factory Sony lamp and have had no problems since. The sets picture is beautiful and I have had no problem since.
SOURCE: my sylvania tv is stuck on standby
This is due to a bad power supply system which consist of an electronical board with capacitors on them that burn out.
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help. Service mode entry and adjust method to many brand TVs are described in detail.
