Question about Sansui Televison & Video
I want sansui 32 inch led tv model LEDTVSJX32HB`2FA SOFTWARE
HE SET IS STANDBY MODE ALL THE SUPPLY ARE OK
  • Patrik Parker Jul 12, 2019
    Please Call Sansui customer Service and Support Call 1 (8O5)*465*751O Toll Free 24x7...
    Top Expert:
  • Sansui Master
  • 55,370 Answers
Contact Sansui directly to inquire.
Posted on Jul 12, 2019
Anonymous
SOURCE:
Anonymous
  • 58 Answers
SOURCE: DIGITAL SOFTWARE UPDATES FOR SAMSUNG 32 INCH LCD TV
you cant force updates, and they may never be another update. updates are only made when there is a problem with the software in the tv
Posted on Mar 12, 2008
bernardlunda
bernard lunda
  • 318 Answers
SOURCE: tv keep going on standby when you turn it on
tv goes into standby all the time if a power supply is not fine, what happens is that a power supply produces two voltages, one small one powers a standby components and bigger voltage powers a line transformer which later produces more small voltages,
then later cancels the first small voltage.
chec your power supply semi conductors like, transistors, diodes and small value resistors, on your power supply. some power supply uses a IC to oscillate a ht. so check a supply at a w/shop.
Posted on Apr 29, 2009
Anonymous
SOURCE: MY ILO LCT27HA36 TV won't come on, it just stays in standby mode/
I had the same problem. Then it worked for a while with me unplugging it and plugging it back in. Then one day it bit the dust. Nothing but the red light.
I found the solution on this website and I am trying to find it to thank the guy who posted it. For less than 10 bucks at Radio Shack, I was able to fix the problem with his instructions. And I know little to nothing about electronics. What it boils down to is this:
1. Lay the TV face down on something soft.
2. Take out the gazillion screws in the back until the back panel(s) come off.
3. Where the power cord plugs in, there is a ground wire going to a screw and another plug that you can undo. On this circuit board lies the problem.
4. Remove the circuit board (there are several other plugs on it. They all fit only one way, so I didn't pay much attention to how they came off.
5. Look on the board at the light blue cylindrical shaped capacitors. I don't remember how many there are, but look at the top of them. Find any that are bulging slightly at the top. They should be easy to spot. I had six on mine that were bulging. If you are handy with a soldering iron, remove the bad ones, making sure where each one comes from. There are a couple of different types/sizes. It is written on the side of each the resistance and what I assume is the voltage.
6. Go to the local Radio Shack and purchase new resistors. Note: I had some that were 1000 um and 36v or something and some that were 440 um and 16v. I couldn't find an exact match on one of those, but according to who I got my instructions from, as long as the resistance (um) number is the same, you can go up in the volts. So I ended up replacing some that were 16v with like 35v but the resistance (um) was the same and there are no problems.
7. Solder them carefully back into place. The circuit board is clear about which hole is positive (+) so don't get them backwards. The ones I bought from Radio Shack had a stripe on the side that was negative.
8. Put it all back together, and there ya have it.
Cheap fix. I admit I was darn skeptical it would work. I had already bought a new tv, but decided I wouldn't be out much if it didn't work. But it is working like the day I bought it again. And, it has a better picture than the Philips LCD tv that I bought to replace it.
Wish I could find the guy I got that info from. I was very impressed and grateful.
Hope this works for someone.
Posted on May 26, 2009
Anonymous
SOURCE: Samsung 32 inch remote control problem
I had a similar problem. Take the batteries out of the remote, press down on the number 5 for about two minutes the put the batteries back in. This worked for me.
(I got this tip from a telesales advisor. I was close to buying a replacement remote but this tip worked. Hope it does for you. I'm not sure on the science part of it but it basically resets the remote. Good luck)
Posted on Jun 21, 2009
Anonymous
  • 113 Answers
SOURCE: Ilo 32 inch LCD wont turn on
power supply bad inside of tv
Posted on Aug 28, 2009
Tda9380ps/n3/3/1664 using sharp set power ok after 5 second on set goes to stand by mode automatically and front led in red.please help me about the problem send circuit diagram through email thanks.
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light. Ple help me
Jan 13, 2018 | Sharp Televison & Video
I have a Insignia NS-L32Q-10A that will not power on. Now power on light or standby. I have replaced the power supply already. All caps look good and fuses check OK. What next???
ok, when you plug in the set, does the power light come on? Assuming you ordered a power supply in good working order, you may very well have a faulty main board. The power supply produces standby power that the main board uses to power the standby/power on light. Your main board also uses the standby power to provide the "ON" signal to turn on the rest of the power supply.
Feb 02, 2013 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
Standby mode
Standby power supply runs 7/24 and this should indicate it is not allowing main power supply and hence the set to turn on= short someplace is most likely issue.
Does red light blink and in a sequence of blinks?
Apr 23, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Set on standby mode,no display aiwa nsz-20hr
There is a short in the power supply board, shorted regulator transistor, or diode, and capacitor, "sometimes a bulge at top" cheaper to replace than repair.
Apr 02, 2012 | Aiwa Audio Players & Recorders
I rescanned the channels after our area has gone digital and this went OK but now the TV won't come on and the standby light just keeps fashing as though its trying to come on. I left it all last night...
You did the opposite of what might be useful. Completely cut of it's AC supply, pull the plug out of the socket and leave it like that for 10 minutes.
Plug back in but first making sure the manual power button is off on the set, not in standby mode.
(pushed in)
Then push the manual button to restore standby mode and switch set into full on mode with the remote.
It will either have "rebooted" and work straight away or you'll need to put it into Auto Set Up mode.
Proceed as the first sections relevant from the instructions.
Sep 22, 2011 | Televison & Video
Define "standby" mode.
The standby mode is a power saving feature. In this mode, a it does not shut down completely, just goes to low power state and so it consumes less power. When it resumes from the standby mode, full power is restored.. During the standby mode, if the power supply is disconnected or interrupted, data might be lost.
Hope this helps,
Lucas
Jul 08, 2011 | Uniden CEZAI998 Phone
I have one Amp;SR4003.if i on the amp;its showing standby light only.which stage defective.pls give me ans; Regards ...
hi,
check the power supply voltages 5v, +-15v. also check the power on relay driver side. also check is there is any dry soldering in power supply stage. check the output amplifiers is there is any transistor faulty. for any further assistance feel free to contact through fixya.
ok
Dec 23, 2010 | Marantz SR4003 Receiver
Hi, I have a samsung cell phone R450 that says silent mode activated and I don't know how to disactivated can you help me please?
Silence the tones your keypad makes when you press a key.
To enter Silent Mode:
In standby mode, press and hold . # button,“Entering Silent Mode” briefly appears in the display and your phone returns to standby mode
To exit Silent Mode:
While in Silent mode and standby mode, press and hold # button “Exit Silent Mode” briefly appears in the display and your phone returns to standby mode.
Adjust the Ringer:
1. In standby mode, press the volume key on the right side of the phone up or down. Options are:
Ringer Off
Vibrate
Low
Low/Medium
Medium
Medium/High
High
Vibrate/High
2. When you are satisfied with the setting, press OK.Your phone returns to standby mode.
Thank You
Aug 17, 2010 | Cell Phones
Panasonic switching to standby mode on its own
Is this a recognised symptom? yes the problem in power supply. it is due to switching oscillator& switcing output circuit probabaly capacitor & transistor. as set is very old so after power supply is ok check for horizontal output also. can it be fixed? yes it is common & not major problem
Oct 05, 2007 | Televison & Video
Re: standby mode???
No really the standby mode dosent mean the sets fried or unrepairable. It just means that the sets in a shutdown mode till a power supply problem is corrected. They have shut down protection when the power supply dosent regulate the b+ and if it didnt shut down it would give off tons of X type radiation. thats just a safty on the set. seek a pro to assist you in repairing the set. Good Luck
May 16, 2006 | Hitachi 50EX01B 50" Rear Projection...
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
