SOURCE: No power from switch mode power supply. Input fuse
you could try shop jimmys.com or look closely at your supply to see if you might have puffed up caps these can like devices will have a puffed up yop from venting if you find some try replacing them the values are on the side
SOURCE: 50PFP5332D/37 has sound and no picture.
try restting push the menu button in on the side for 5-6 second
SOURCE: vizio vp322 No power, no amber light. Replaced
Hi the first thing I would ask is are you sure that power supply that you bought is good? If you are sure your power supply I would check the power filter that connects the power cord to the power supply to make sure there is voltage getting to your power supply. If that checks out the only other thing to check is the signal board. You can check to see if there is power getting to your signal board if there is then it's provably your signal board. You can find parts for that TV at http://www.interliquidparts.com/products-page?product_search=vp322&view_type=default
SOURCE: will a power supply for a 50" plasma TV work with a 42" plasma TV?
sir it will work with your TV..
