COMES OUT OF THE BOX 8.1 WINDOWS INSTALLED AND CAN BE UP GRADED TO WINDOWS 10
I understand your concern, these systems are daunting.
Open the box plug it in hit the start button and first screen is usually pick a language.
These new Windows OS are very user friendly and think it will guide you thru the process of getting started and connecting to the internet.
Depending where you purchased the PC many stores have help service at their locations.
Always maintain a secure physical backup(removable drive) for your priceless photos, music and documents. When these systems crash it is a train wreck trying to recover lost documents. Protect your personal information CC and the like.
If you have a second computer near by I would search for answers to questions as I go.(Microsoft websites are very helpful)
Updating to 10 early in the process is probably a good idea.
Saying "no" more than yes when it asks for more information.
Recently having to replace my tried and true XP has turned out to be a delight. In the whole process just plugged in the new and loaded up the programs that I used the most. I still keep the old XP running and have connected the two together to share the files to make it a little easier in the transition.
Hope this has helped?.
Your planer is equipped with a turret stop (M), shown in
Figure 11, for repetitive planing of pre-set depths. Stops are
set at 0", 1/4", 1/2" and 3/4". Use the 0" setting when planing
between 1/8" and 1/4".
TO SET A PLANING DEPTH
1. Be sure the carriage is set above 1-1/4" before trying to
set the turret stop.
2. Turn the turret stop until the desired measurement
shows (Fig. 11).
3. Unlock the head lock lever (Fig. 8). Turn the depth
adjustment crank, lowering the carriage by the desired
increments, until it contacts the turret stop.
NOTE: DO NOT USE FORCE TO CRANK THE CARRIAGE
BELOW THE LEVEL THAT THE TURRET STOP INDICATES.
PERMANENT DAMAGE TO THE HEIGHT
ADJUSTMENT SYSTEM ON YOUR PLANER WILL
RESULT.
NOTE: The 3/4" turret stop can be adjusted for other planing
thicknesses. Adjusting the 3/4" turret stop does not affect the
other turret stop settings.
TO ADJUST THE 3/4" STOP FOR OTHER
THICKNESSES
1. Unlock the head lock lever (Fig. 8) and turn the adjustment
handle counterclockwise to raise the cutter head.
2. From the back of the tool, locate the turret adjustment
bolt (N) shown in Figure 11. This bolt is set for a 3/4"
depth of cut at the factory. Use the crescent wrench provided
to loosen the jam nut. Adjust the bolt up or down to
reach the desired planing depth.
3. Turn the depth adjustment crank, lowering the carriage by
the desired increments, until it contacts the turret stop.
Hope this helps.
