Monitor turn dark frequently
it sounds like your PC trouble, you may try (it is better to make sure the monitor connect other PC ok)
1) check PC ram, change ram sticks position if there are two ram stick, or change a new ram if only one ram inside. not fix go next
2) check VGA cable connection, reseat the cable. still not fix go next
3) if you use AGP VGA card change VGA cable to onboard VGA interface (setup bios VGA to onboard),
is this helpful to you olease feedback thanks.
Hi Mario Miller, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
1. What exactly is the problem with Monitor?
2. Were you able to narrow down the issue whether Software or Hardware?
