It sounds like there may be an issue with the belt or the motor in your Smith Corona super-correct electric typewriter. The ticking and grinding noise could indicate that the belt is slipping or that there is an issue with the motor. It's possible that the belt may have come loose or slipped out of place during use, causing the ticking noise and the typing issues you're experiencing.
To troubleshoot the issue, you could try removing the casing of the typewriter and inspecting the belt to see if it's in place and properly tensioned. You could also try cleaning the mechanisms inside the typewriter to see if that helps. If you're not comfortable doing this yourself, you may want to take the typewriter to a professional for repair.
In any case, it's important to be careful when working with electrical equipment. Always make sure the typewriter is unplugged and the power cord is disconnected before attempting any repairs or maintenance.
How to Use a Smith Corona Typewriter
A Smith Corona typewriter can be either a manual or electric model. Whichever model you have, the typewriter works in basically the same way. If you are familiar with a computer keyboard, you can type on a typewriter as the keys are laid out exactly the same. Unlike a computer, typing mistakes are harder to correct and, unless you use carbon paper, you will only have one copy of any document you type. A Smith Corona typewriter can be either a manual or electric model. Whichever model you have, the typewriter works in basically the same way. If you are familiar with a computer keyboard, you can type on a typewriter as the keys are laid out exactly the same. Unlike a computer, typing mistakes are harder to correct and, unless you use carbon paper, you will only have one copy of any document you type.
You did not specify if it was a manual or electric or the model, so assuming it is a standard manual or electric machine, push down on the shift key and hold it, then type your letter or letters. If you are typing everything in caps, press the shift lock key.
Sounds like a broken wire attached to the carrier motor. If you remove the shell from the typewriter you can see the wiring inside. I suspect one of the wires has come disconnected or broken. Replace the wiring assembly or you can try to strip the two ends of the broken wire and twist them together, then use some electrical tape to secure.
MARGINS: Left margin space or tab to where you want margin set and depress the mar L key. Sometimes the key has to be depressed as you hit the code key. If you want to move carrige to the left, go to margin hit margin release and bk space to where you want. Same with the right margin only use th R margin key. Code key usually keys have second message are in green, yellow or red. Use code key with the small print on the key to activate that function.... Good luck
the lift of tape has a dull side and a bright side make sure the dull side is toward the paper then press and hold the code key and the = key to reset the typewriter also see page 6 in the owners manual
