20 Most Recent Smith Corona S.c.m. Electra 120 Portable Electric Typewriter Case Nice Questions & Answers
Take the botton cover off. then hand move the belt while pushing the one key down. when it pops up hold it. From the bottom you will see the flat link, it has a clevis, or a split in it, you need ot attach it to the
key lever you moved up. .
OR OR OR OR just use the lower case L it is the same as a number one.
Smith Corona... | Answered on Jul 02, 2016
with a small screwdriver open the clevis and reattach the link to the typebar
Smith Corona... | Answered on Jan 29, 2016
Vendors that display a copy of the manual in their ads might be contacted to request a copy of the manual.
Example:
https://www.amazon.com/Smith-Corona-DeVille-470-Correctable/dp/B003TZBMX2
Smith Corona... | Answered on Jun 15, 2020
Remove print wheel...clean with soapy water
Smith Corona... | Answered on Jan 27, 2020
Most likely bad printwheel, spokes may be catching on the ribbon and not going to home position. Try a new wheel, and or make sure carrier is returning to home position every time. make with white out the top of the print wheel spoke at home position and make sure it always comes back to that spot when you turn machine on and off and on. This will tell you if the machine is starting in the same place every time.
Smith Corona... | Answered on Mar 25, 2019
What happens, any noise, etc. some times the chrome rail
inside the machine gets sticky and will not let the carrier move. Also if you hit the carriage return key and nothing happens, my be bad keys or keyboard...
Possible bad wheel or spooks are bent and not going to home position. Look at wheel
Smith Corona... | Answered on Feb 22, 2019
Smith Corona S.c.m. Electra 120 Portable Electric Typewriter Case Nice Logo
3 questions posted
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Ekse
James Keysor
Level 1 Expert
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Smith Corona Office Equipment & Supplies
Most Popular Question
1 key not attached mechanism apart fix
  • Office Equipment & Supplies
