Question about Smith Corona Office Equipment & Supplies
Typewriter is not printing dark enough. Is there
Typewriter is not printing dark enough. Is there some way to make it print darker? It has been in storage for years and I replaced the ink catridges but you have to type the letters several times to get it dark enough to see.
  • Anonymous Aug 25, 2009
    The typewriter is a Smith Corona Deville 110. The ribbon I have is porelon brand for H series typewriters. I bought the ribbon at office depot and came straight home and put it in. Thank you for your help.
  • P McD May 11, 2010
    Not enough information is given. What brand of typewriter and what kind of ribbons? Carbon ribbons can dry out and not print correctly if not packaged or stored in heat. Humidity can also ruin carbon ribbon over long periods of time. If the machine is and IBM selectric it could be your ABC control lever is pushed to the back instead of being pulled all the way forward. These may help answer your question, but without knowing the details it is a shot in the dark. Hope this helps!
P McD
  • 46 Answers
Many SCM typewriters have an impression control knob on them. Look for a knob on either the right or left side of the the keyboard with numbers from 1 to 10. The higher the number reading the darker it is supposed to print. Be careful not to go so high that the typeface cut holes in the paper. If this doesn't help, try putting a drop or two of sewing machine oil (or Triflow Oil) on your finger and rubbing it across the typebar segment (the slotted and curved metal piece that the typebars pivot in). Since the typewriter sat a while the segment may be sticky. Hope this helps.
Posted on Aug 25, 2009
Testimonial: "Fast, great help!! I really appreciate it."
HOW TO INCREASE DARKNESS IN HP 4300
1. If you are printing using postscript driver, try using PCL6 - printout would be darker for grey scaled items.
2. Print in lower resolution 600dpi or 300dpi, printouts would be darker.
3. Try printing all characters as black
You can adjust darkness at the printer using the console menu.
In the Configuration Menu ' Print Quality sub Menu , there is a parameter called Tonor Density. Factory Default is 3. Set to 4 or 5 to increase darkness..
Sep 27, 2013 | Office Equipment & Supplies
How do I adjust the keys on an Olympia Socialite manual so they can strike darker letters?
This is a manual typewriter, the harder you press the darker the print. You might try a fresh ribbon.
DickyO
Jul 07, 2010 | Olympia Traveller C Typewriter
Print is to light. How do I get it to print darker
there is a option u can do it dark and light,,,
press dark or light botton, than its gives u dark print ,,
if there is ok than change your cartridge,
May 04, 2010 | HP Officejet 5610 All-In-One InkJet...
The black is not printing dark enough. It shows it
it is problem your printer black cartridge
you change it or
technicaly you drop your black cartridge in water withen two days after tow days you dry black cartridge and clean head printer maintai nence software then solve your problem
Jul 30, 2009 | HP DeskJet 5550 InkJet Printer
Printer not printing dark enough
go to the print settings select the dark scale
u can get print darker than the previous
May 27, 2009 | Samsung CLX 3160fn All-In-One Printer
Type is faded and old looking even with new ribbon.
Put in a multi part form, if the carbons print well then try a fresh ribbon,. not one that has been sitting around for a long time. If it is bad check for debris around the print hammer, If its clean either the print solenoid is gummy or the solenoid cap is broken.
DickyO
Jan 06, 2009 | Lexmark Wheelwriter 1500 Typewriter
HP 5550 Laserjet prints dark
The only time I saw a color laser Printing darker than normal the issue was tranfer belt. The condition you describe matches the problem I was involved in and the tranfer kit fixed the problem.
Hope this helps
Aug 28, 2008 | HP LaserJet 5550 Printer
Improving bar code image DPI for a darker output
Datamax Program Language (DPL) uses pcx and bmp graphic formats. The Adobe image must be opened in Adobe Reader and print using a windows driver. Use the datamax windows driver from www.seagullscientific.com
Jun 12, 2008 | Datamax DMX I-4206 Printer
1,477 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Ekse
James Keysor
Level 1 Expert
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
