The remote is working (beeps, flashes etc...) however, it is no longer starting my car or performing any of the functions it did previously. Anyone know how to fix this?
Hi, a simple ques. Or two. First is ur led a solid color or flashing? If its solid its in valet mode. Next, if u have a defective switch, i.e. hood, make sure its operating . Last, that alarm has a manual switch to shut down the auto start. Fun. Its for safety so it wont start when servicing the vech. Find it snd make sure its not in bypass .
SOURCE: Remote starter stopped working
Will you rate my answer from my clarification as a solution about the antenna thanks Mike humble.
SOURCE: got a new remote for my viper 791XZ and reprogrammed it .
this usually means that the remote did not recieve a signal back from the module or the module did not recieve the remote signal
have you tried repeatively to press the unlock button? does the remote starter work or aux( trunk ) ?
also when putting the battery in the remote , be easy because there is a connector plug soldered on the board real close to where the battery is , and if it is hit by the battery hard enough it will cause those solder connections to disconnect and you will get the beeps and or other malfunctions
SOURCE: My Viper 791xv remote isn't receiving the page
My battery ran low and I jump started my car which some how caused the problem. My viper technician made me a buy new remote but the problem continued even with the new remote.
Try disconnecting the battery of your car for ten minutes and then reconnecting it. It worked for me. Now i have a extra remote which i don't need.
SOURCE: viper 5701 remote issue
sounds like the remots have lost two way communication. try to disconnect the windsheild antenna.try remotes again after pluging antenna back in.
SOURCE: My viper 5701 2way remote works, but gives buzz for all functions
hi did you get this unit from ebay? i am going through the same experience right now and there is a problem with the early units that were manufactured. It will need to be replaced. I am currently trying to get a refund.
