Question about Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6 Turbo Diesel Snorkel Air Intake Hose
I need a fuse panal diagram for the 2013 VW Jetta, my 12 volt power ports are not functioning
karl kuhn
    Problem Solver:
  • 19 Answers
Here you go. Fuses on E-box, on left in Engine Compartment
Fuse 1 - Not assigned
Fuse 2 - 10/15A - Engine control unit
Fuse 3 - 5A - Radiator fan control unit
Fuse 4 - 5/10/15A - Lambda probe heater,
Lambda probe 1 heater after
catalytic converter
Fuse 5 - 10A, 20A - Lambda probe heater1,
catalytic converter,
Fuel system diagnostic pump,
Charge pressure control solenoid
valve,
Exhaust gas recirculation cooler
change-over valve,
Crankcase breather heater element,
Vacuum pump for brakes
Fuse 6 - 5A, 10A,15A - Fuel system diagnostic pump,
Throttle valve module,
Activated charcoal filter system
solenoid valve 1,
Continued coolant circulation pump,
Auxiliary air heater heating element
Fuse 7 - 20A, 5A - Ignition transformer,
Fuel pressure regulating valve,
Fuel metering valve
Fuse 8 - 10A - Throttle valve module,
solenoid valve 1
Fuse 9 - 5A - Automatic glow period control unit,
Electric fuel pump 2 relay,
Fuel pump relay
Fuse 10 - 5A - Speedometer sender,
Brake light switch
Fuse 11 - Not assigned
Fuse 12 - 5A - Coolant circulation pump
Fuse 13 - 5A - Water pump
Fuse 14 - 5A - Engine control unit
Fuse 15 - 30A - Voltage stabiliser
Fuse 16 - 30A - ABS control unit
Fuse 17 - 30A - Automatic gearbox control unit
Fuse 18 - 20A - Automatic gearbox control unit
Fuse 19 - 1A - Onboard supply control unit
Fuse 20 - 30A - Onboard supply control unit (AW0)
Automatic intermittent wash and
wipe relay (AW1)
Fuse 21 - 50A - Secondary air pump motor
Fuse 22 - Not assigned
Fuse 23 - 40A - ABS control unit
Fuse 24 - 50A - Trailer detector control unit
Fuse 25 - 50A - Terminal 15 voltage supply relay 2
Fuse 26 - 60A - Automatic glow period control unit
Fuse 27 - 60A - Radiator fan
Fuse 28 - 40A - Onboard supply control unit (AW1)
Fuse 29 - 40A - Onboard supply control unit (AW1)
Fuse 30 - 50A - Terminal 75 voltage supply relay 1
Fuse 31 - 30A - Amplifier
Fuse 32 - Not assigned
Fuse assignment - Interior Fuse Panel
Fuse 1 - Not used
Fuse 2 - 5A - Electronic steering column lock control module
Fuse 3 - 10A - Instrument cluster control module
Fuse 4 - Not used
Fuse 5 - Not used
Fuse 6 - 10A - Vehicle electrical system control module,
Interior ceiling lights,
Tail lights
Fuse 7 - 5A - Fog lamp relay,
Instrument panel and switch illumination dimmer switch,
License plate lamps,
Fuse 8 - 7.5A - Windshield and headlamp washer pump switch,
Windshield washer pump
Fuse 9 - 5A - Airbag control module
Fuse 10 - 10A - Right steering column switch
Fuse 11 - Not used
Fuse 12 - Not used
Fuse 13 - 5A - Automatic dimming interior rearview mirror,
Light recognition sensor,
Parking aid control module,
Air quality sensor,
High pressure sensor,
Climatronic control unit,
Tire pressure monitoring button,
Back-up lamp switch,
Left washer nozzle heater,
Right washer nozzle heater,
28-pin connector
Fuse 14 4- 10A - Left steering column switch,
ABS control module,
Light switch,
Airbag spiral spring/return spring with slip ring,
Fuel pump control module,
Data bus on board diagnostic interface
Fuse 15 - 10A - 16-pin connector (diagnostic connector),
Headlamp range control adjuster,
Auxiliary heater operation relay,
Mass airflow sensor,
Positive crankcase ventilation heating element,
Left front headlamp,
Left headlamp beam adjustment motor,
Right front headlamp,
Right headlamp beam adjustment motor,
Fuse 16 - 10A - Engine control module
Fuse 17 - Not used
Fuse 18 - 15A - Left front headlamp
Fuse 19 - 15A - Right front headlamp
Fuse 20 - 10A - Automatic transmission control module,
Selector lever sensor system control module,
Tiptronic switch,
Ignition/starter switch
Fuse 21 - Not used
Fuse 22 - 10A - Ignition/starter switch,
Converter box,
Alarm horn,
Interior monitoring sensor,
Alarm horn relay,
Dual tone horn relay
Fuse 23 - 10A - Vehicle electrical system control module,
Light switch,
Rain/light recognition sensor,
Compass magnetic field sensor,
Fuse 24 - 10A - Vehicle electrical system control module,
Access/start authorization control module
Fuse 25 - 15A - Automatic transmission control module,
Multifunction transmission range switch
Fuse 26 - 15A - Brake system vacuum pump
Fuse 27 - Not used
Fuse 28 - 40A - Auxiliary heater operation relay
Fuse 29 - 1A - Vehicle electrical system control module,
Fuse 30 - 20A - Cigarette lighter,
12 V socket,
12 V socket 2,
Blocking diode
Fuse 31 - 30A - Light switch
Fuse 32 - 20A - Light switch
Fuse 33 - 40A - Heater/heat output switch,
Fresh air blower relay,
A/C control module,
Fresh air blower switch
Fuse 34 - 15A - Left front headlamp,
Fuse 35 - 10A - Steering column electronics control module,
Instrument cluster control module,
Signal horn activation,
Fuse 36 - 25A - Vehicle electrical system control module
Fuse 37 - 15A - Left front headlamp DRL
Fuse 38 - 15A - Right front headlamp DRL
Fuse 39 - 15A - Low beam relay
Fuse 40 - 15A - Towing recognition control module
Fuse 41 - 15A - Towing recognition control module
Fuse 42 - 20A - Towing recognition control module
Fuse 43 - 30A - Front passenger door control module
Fuse 44 - A25 - Rear window defogger relay,
Fuse 45 - 30A - Driver door control module,
Fuse 46 - 30A - Left rear door control module,
Right rear door control module
Fuse 47 - 15A - Fuel pump control module,
Fuel pump relay,
Fuel primer relay
Fuse 48 - 20A - Vehicle electrical system control module,
Fuse 49 - 20A - Climatronic control unit,
A/C control module
Fuse 50 - 30A - Front seat heating control module
Fuse 51 - 30A - Power sunroof control module
Fuse 52 - 20A - Dual tone horn relay
Fuse 53 - 15A - Front seat heating control module
Fuse 54 - 15A - Fog lamp relay
Fuse 55 - 20A - Light switch,
Fuse 56 - Not used
Fuse 57 - 15A - Radio,
Radio/navigation display unit control module
Fuse 58 - 1A, 30A - Telephone transceiver
DC/AC converter with socket, 12V-230V
Fuse 59 - 30A - Amplifier
Fuse 60 - 30A - Auxiliary heater control module
Posted on Jul 22, 2014
I need a fuse panel for 2013 vw jetta 2.5 SE
type the diagram you want into google images you may find it there.
Dec 29, 2016 | 2013 Volkswagen Jetta
My 2007 Volkswagen Jetta is stuck on parking gear
VW Jetta neutral override trick - YouTube
? 1:31
https://www.youtube.com/watch?v=GFw2j6ufTH8
May 28, 2013 - Uploaded by Pop Acap
This 2005 VW Jetta SE was involved in a motor Vehicle Accident and ... I had troubles with my vauxhall zafira 1 ...
STUCK IN PARK!!! - Volkswagen Forum - VW Forums for Volkwagen ...
volkswagenforum.com > ... > VW MODELS > Volkswagen Jetta/Bora
Aug 10, 2006 - i was driving into my apartment complex, and i put my car in park ... He checked the shift lock, fuses, brake light switch, computer stuff ... Automatic ShifterStuck in Park, waldo358, Volkswagen Passat, 1, 12-27-2007 05:23 PM.
Automatic stuck in Park - doesnt seem to be brake switch - TDIClub ...
https://forums.tdiclub.com/showthread.php?t=323777
Jul 12, 2011 - Automatic stuck in Park - doesnt seem to be brake switch VW ... TDI(s): 2002 VW Jetta TDI Manual(performed 01M to 5-speed swap) .... Bad Brake light switch - stuck in park, Joe Golf, TDI 101, 2, November 25th, 2007 17:48. Audi A6 Stuck In Park - Read More
Oct 17, 2015
PRNDS Lights Flashing, Stuck in First Gear
Dec 31, 2013
Help Plz! Jetta Shifter Wont Shift from Park!
Dec 17, 2010
More results from forums.tdiclub.com
Dec 30, 2015 | Volkswagen Cars & Trucks
What i need is a fuse panel diagram for 2013 jetta tdi
Best bet....go to the Service Department at the nearest VW
Dealership.
Aug 09, 2014 | Volkswagen 2013 Jetta SportWagen TDI
Need diagram for 12 volt power port for 2011 vw jetta 2.5 se
I have same problem and the local dealer told me to try fuse number 15 of 75 should be a blue #15 .... located inside the car on the drivers side. I bought fuses today - will try to fix tomorrow and will repost of my success.
Nov 11, 2012 | 2011 Volkswagen Jetta
2011 VW Jetta TDI I want to know which fuse goes with the power outlet in the front console.
Hello. Both of my 12v outlets went out @ the same time on my 2011 Jetta TDI. Our dealership wanted us to bring it in to have it fixed. I decided to do some research and Pepboys came to the rescue. They printed me a fuse box diagram and a list of what goes w/ what fuse. Fuse location #30 is connected to the 12 v . It is a light yellow 20Amp fuse. It cost 4 dollars for 2 fuses and solved the problem.
Jul 18, 2012 | 2011 Volkswagen Jetta
I need a fuse panel diagram for the 2011 vw jetta tdi. my 12 volt power ports are not functioning.
For 2011 VW Jetta 2.0 TDI, the 12 Volts power ports (cigarette lighter) fuse 20A (yellow) is placed in the fuse box on passenger's side = F42. See pictures below:
F42 (20A) = 12 Volts ports - cigarette lighter
Jun 01, 2011 | Volkswagen Jetta Cars & Trucks
My cigarette lighters do not work to charge my cell phone? could this be a fuse problem? If so, which fuse is it?
Yes, could be cigarette lighter fuse blowed. Check fuse no.# 42 - F42 (20A) = cigarette lighter, 12 Volts. See picture below:
For 2006 VW Jetta the fuse box is located on the left side of dashboard behind a plastic cover (for left hand steering wheel vehicle). On inner face of the plastic cover you will find the fuse diagram.
Aug 24, 2010 | 2006 Volkswagen Jetta
Which fuse goes with the power outlet - 2004 VW Jetta TDI
if you don't have an owners manual try here for owners manuals online: www.edmonds.com
you can also get a 12 volt tester and find it that way
Mar 19, 2009 | 2004 Volkswagen Jetta
Vw Mk1 Rabbit Caddy Jetta Pickup Golf 1.6 Turbo Diesel Snorkel Air Intake Hose Logo
11,550 people viewed this question
Top MK1 Originals Vehicle Parts & Accessories Experts
mekanik84
Rigger DeBusk
Derrick Schultz
Derrick Schultz
Are you a MK1 Originals Vehicle Part and Accessory Expert? Answer questions, earn points and help others
