20 Most Recent Gmc Dodge Ford Reverse Back-up Sensor Alarm Kit Questions & Answers
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U can also get free manuals
Gmc Dodge Ford... • Answered on Jan 24, 2019
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Gmc Dodge Ford... • Answered on Jan 06, 2016
Normally, you will have to reflash the ECU. You will need to got to Halfords or any shop that has it. Then locate the port under the steering wheel. turn the car on and it should work.
Gmc Dodge Ford... • Answered on Jan 19, 2014
Seat belt sensor or seat sensor or you have a heavy parcel on the passenger seat
Gmc Dodge Ford... • Answered on Oct 23, 2013
The programming procedure for Prestige/Pursuit remote is as follows:
First, locate the programming/valet switch. For newer model units the programming switch is located in the antenna, previous models have a push button LED (PBLED). Older models have a plain black push button, usually located near the driver's side kick panel (where your left foot would rest when driving).
After locating the programming switch; turn ignition on, press and release switch three (3) times,parking lights will flash once. This is channel 1 (lock button). Press lock button on remote. Parking lights flash once. Press and release switch one (1) time. Two flashes (channel 2). Press unlock button on remote. Press and release switch one (1) time. This is Channel 3 (trunk/remote starter), press the channel three button on remote. Repeat process for additional channels. Once you have programmed all available channels, turn ignition off to exit programming.
Gmc Dodge Ford... • Answered on Jan 21, 2011
just replace your battery you have a central control module, that stays programmed, the only way you need to get it reprogrammed is if you take it out and put it in another car
Gmc Dodge Ford... • Answered on Mar 15, 2010
if you change your batteries on your remote, you don't have to worry, it stays programmed
changed battery 2004 ford explorer and service engine soon came on
Gmc Dodge Ford... • Answered on Oct 09, 2009
did it get bumped? does it crank? if it did possible could be the fuel cutoff switch usually located in trunk or driver kick panel
Gmc Dodge Ford... • Answered on Aug 11, 2009
could be the crank sensor off the flywheel should be on the trans.
That little "S" is the power save feature. Press the "F" and the lock buttons together to toggle the feature on and off. With the S on the battery in the transmitter will go into a power down mode when alarm is in disarmed state to save battery life.
Gmc Dodge Ford... • Answered on Aug 09, 2009
The lock/unlock outputs from the main unit are reversed. There are two negative output wires from the unit that control the doorlocks, if you just switch them around, they will function correctly.
Gmc Dodge Ford... • Answered on Jun 04, 2009
Yea this will be because most alarm systems are fitted to the bonnet, or got a shock sensor in it.
This is becuase it stops people from openings the bonnet and removings the alarm system from the battery then stealing your car.
So its nothing to worry about really
Gmc Dodge Ford... • Answered on Apr 04, 2009
there should be a shock sensor under your dash. Its about 1X1X1 in size and it should have some lights on it. it will have a dial on it that you will be able to turn the sensitivity up on it
Gmc Dodge Ford... • Answered on Feb 16, 2009
Gmc Dodge Ford Reverse Back-up Sensor Alarm Kit Logo
35 questions posted
Top Toyota Vehicle Parts & Accessories Experts
xxxxxx xxx
robert
 Mikey
Mikey
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Toyota Vehicle Parts & Accessories
Most Popular Question
identical prestige remote not
  • Vehicle Parts & Accessories
