A blinking green light on a Segway Ninebot charger typically indicates that the charger is properly connected and charging the device, but the battery is not yet fully charged. Once the battery is fully charged, the light should turn solid green. If the light continues to blink green and the battery does not charge, it could be an issue with the charger or the battery. Try using a different charger or testing the charger on another device to see if it is working properly. If the issue persists, contact Segway Ninebot customer service for further assistance.
Blinks of green light is a bad indication. It is related mainly to the display panel. If you wish to get more details, check the site linked here. Pull up older posts. Screen shots to defective FPTVs are given in detail.
The green light blinking in the back indicates that the power supply went bad and is not turning on, go ahead and get the power supply replaced. Normally that light is supposed to be fully lit and green.
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf But to answer your question here is what the difference between the green light and the red light are: 1. X-Band Signal Indicator—A green LED lights and blinks to indicate the presence of an X-band radar signal. The blink rate increases as the radar source gets closer. A distinct audio alert is also heard. 2. K-Band Indicator— An amber (orange) LED lights and blinks to indicate the presence of a K-band radar. The blink rate increases as the radar source gets closer. A distinct audio alert is also heard. 3. Ka-SuperWideband Signal Indicator— A yellow LED lights and blinks to indicate the presence of a Ka-SuperWideband radar signal. The blink rate increases as the radar source gets closer. A distinct audio alert is also heard. 4. Laser Signal Indicator— A red LED under L lights and blinks to indicate the presence of a laser signal. A distinct audio alert is also heard. 5. SWS Signal Indicator— When an early warning hazard or informational signal is detected, the yellow SWS LED begins to blink and the amber K-band LED lights. A distinct audio alert is also heard. 6. Power-On Indicator— A green LED under P lights to indicate power is being supplied to the unit and the unit is turned on. 7. LED Signal Strength Meter—Four LEDs give an accurate visual indication of the strength of radar or laser signals. 8. City Mode Indicator—A green LED under C lights to indicate that you selected City Mode. 9. Auto Mute Indicator— A red LED under M lights to indicate that you selected the Auto Mute feature. Please make sure you give me a rating and I hope this helps, cbinny1
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category. http://servicemanuals.vstore.ca/
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing? If you get no noises this usually indicates a board fault and you should look for a new printer.
