To connect the upholstery tool, first remove the clean water tank by pressing down on the handle and pulling the tank forward. Remove the hose from the storage rack. Press down on the handle release lever and lower the handle to the ground. Unlatch the back part of dirty water tank and remove the lid. Pull the dirty water tank's front panel up about an inch and rotate the panel to parallel with the floor. Replace the panel with the converter and slide it halfway down until it is firmly in place. Pull the collar on the connecting tube towards the tube so that the black tabs are fully extended. Open the door on the hood labeled Stair/Upholstery cleaning connection and press the round solution tube onto the round projection. Press the collar firmly to ensure that the tube is connected. Replace the tank in a hinge-like manner and place the lid under the tabs on the front of the tank. Rotate the lid down onto the tank.
Now slide the upholstery tool on the connector of the hose until the tab locks into place.
The manual for the Spin Scrub 50 is available on the Hoover product page: http://hoover.com/products/details/fh50044/steamvac-spin-scrub-50-carpet-washer-with-tools/ . The direct link to the manual is http://hoover.com/file/1195/ . The directions are on page 14-15.
I hope this helps.
