SOURCE: SHARP AR5516 PAPER JAM ERROR MESSAGE
when you open side door in the up you see a black unit check if sesor not broken. also open cassete and see inside no paper jam there
SOURCE: my sharp ar5516 use to
For H4 enter the following codes
# interrupt
C interrupt
14 Start button twice
For ch
check whether all the doors(side door,front door) are closed.
SOURCE: in sharp ar5516 F2 CODE DISPLAYED
Try this. On the panel. Press # * C *. Your screen will change to a diagnostic mode.
Enter the number 14 , as if you were going to make 14 copies.
You may have to enter 1 , then press start. But follow the display directions.
The 14 will clear F codes. This should resolve your problem.
