SOURCE: I am trying to get
You should press SHIFT then MODE (setup). Then press 2. Done! If you want to change it back, just do the same again, but press 1.
SOURCE: fractions multiplied by fraction to get fraction
In the CATALOG there is a >Frac command that can be used with parentheses to multiply fractions.
(1/2)(1/3)>Frac
1/6
SOURCE: multiplying exponential numbers
I am needing to find out what key I can push for an exponent. I have an exponent that is 2520 and I dont know what button to push for it.
The problem is as follows:
3000 ( 1+ 0.06/360) exp.2520
3000 ( 1.000166667) exp. 2520
3000 - 4565.72
Final Answer
1565.72
Now how in the world did they get 4565.72. What buttons am I needing to push.
SOURCE: my calculator won't give me decimal numbers
Use the [S<->D] key to switch between the two.
Hope it helps.
