Turn it off, remove the stock, tap the sides with a block of wood and scrape to the bottom of the freezer with a dustpan and scoop it out. Refit the stock and switch back on. Takes 10 minutes. Check the lid seals properly once defrosted and check it's not accidentally in superfreeze mode.
I WOULD TAKE THE LID OFF AND REPAIR IT, USE SILICONE,ALCOHOL TO CLEAN BOTH SURFACES, AND SOME SMALL POP RIVETS.. GO TO ACE HARDWARE AND ASK ONE OF THE GUYS FOR THIS STUFF, ASK HIM FOR RECOMMEND REPAIR TECHNIQUES PICTURES OR THE LID IN THE BACK OF YOUR TRUCK, SO HE CAN SEE IT .. CUZ FLAT OUT YOU AINT GOING TO FIND A LID, AND IF YOU DO DON'T BE SURPRISED IF ITS 200$ OR MORE .. JAY THE PUMP REPAIR GUY FLORIDA
I have the same problem. Could be 2 things. 1) The top lid may not be all the way down sealing. I had to out some weights on top to make it seal better.
2) The lid seal could be cracked, partial missing or just not sealing. Good luck trying to find a new seal. I'm still looking.
Hi, sounds worse than just the bulb if you heard it bang, I would get it looked at, electricity can kill and your light is in the lid and you touch the lid to open it.
Hope that helps. Dont forget to vote for the solution.
if your freezer has the sping etc in each of the hinges, then yes take them off. If your freezer has a torshon bar type spring, DO NOT take the hinges off, as you will not get it back together
i have always replaced liners with the door attached. The lid of the freezer is going to bow out of shape when you remove all the screws and take the old lining off, so you need to replace the lining and leave the screws loose so you can realine the door bit by bit.
it is a bastard of a job, and i wish you all the best.
