The liner is no longer available for the lid. I found the same type of plastic used for the liner. I'm going to remake the liner, but how do you remove the lid from the chest. There is a bolt head screw at the back of the chest on both sides. I am assuming that once those screws are removed the lid will come off. Will it be just as easy to put it back?
If your freezer has the sping etc in each of the hinges, then yes take them off. If your freezer has a torshon bar type spring, DO NOT take the hinges off, as you will not get it back together
i have always replaced liners with the door attached. The lid of the freezer is going to bow out of shape when you remove all the screws and take the old lining off, so you need to replace the lining and leave the screws loose so you can realine the door bit by bit.
it is a bastard of a job, and i wish you all the best.
