It is keeping a holding temp of 50 and needs to be 40 we have changed the temp control switch but it will freeze up over night and stay too warm during day when we are in and out a lot
SOURCE: beer box tempature control not getting cold enough to temp. specs
check the vendilation condition/temprature out of the freezer
SOURCE: keeps running and freezing eveything, replace temp switch still freezing up
No the temp wire should be not on top of the coil but running down the middle all the way down to the bottom of the cooler. Try this first and if it doesnt work let me know
SOURCE: do I have to use a TRUE thermostat on my T-72?
The True thermostat sits on the evaporator in a piece of tube attached to the coil. If it won't switch off at your required temp even at position 1 you can use an air temperature type thermostat in it's place. It will sit in the same place but the sensing end will coil up behind the fan. Get a bar fridge thermostat and it'll adjust to your needs.
